Question about Frigidaire FMV156EM Microwave Oven
HOW TO REPLACE DOOR SWITCH ON A GE STOVETOP MICROWAVE
  • Frigidaire Master
  • 9,085 Answers
It depends on the model number, but I'm guessing you mean it's an over the range model.
If so, you only have to remove the grille and controller assembly to get to the door switch mounts.
Our help file on door switches is here.
A YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes is here.
Posted on Dec 12, 2012
WHERE CAN I FIND A DOOR SWITCH FOR MY GE MICROWAVE WES1384SM2SS
Most microwave ovens use generic "microswitches" for door switching. You will need to open your oven, and find what they look like, and then match them.
I bought replacements here:
Allied Electronics Electronic Components Distributor
but any electronics distributor will have them. Inexpensive, only a few dollars eacy. My ovens actually use 4 switches on the doors, and more than one were bad.
Jun 04, 2015 | GE Microwave Ovens
Why has my Microwave stopped working? e130mh55gsa installed over stovetop. simple commands like cook for 1 minute, etc do not work anymore. manufactured January 2008. serial number 7g80305394. 12
Most commonly problem of Microwave Oven is the interlock switch in its door hinges. Since it is emitting microwave rays, it was built with such interlock switch to avoid exposure of human to said rays. So check first the continuity and functionality of said door switch.
Jan 10, 2015 | Microwave Ovens
Why does my ge spacemaker jvm1740dd1cc no longer heats and the turntable does not work?
Bad door switch. Look for burnt terminals on one of the door switches. Replace the switch and cut off the burnt terminals and splice on new ones.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
What can cause a microwave to come on when the door is opened, never seen this before and is very dangerous. it happens with or without time set.
The most likely problem is a faulty door switch, you can buy new switches, but you'd have to follow the diagram here to identify which of the 2 switches you need to replace: See Part # 26
http://www.partselect.com/Schematics/GE/00008593i01.gif
you can find the parts here:
GE WB24X830 Monitor Door Switch PartSelect
GE WB24X829 Secondary Door Switch PartSelect
Jul 14, 2014 | Microwave Ovens
Unit will only work one time /then you have to wait 10-15min
ge over the range microwaves have this problem . for some reason the plastic sort of melts but not realy (please check hinge for wear and adjust if ness ) , it just gets out of shape from the heat and this makes the switches not work properly . most likely the micro is too close to the stovetop . see your manual about that and you can buy the slideing plastic parts where the switches are , its just big $$$$ if the micro is to close it will happen again GOOD LUCK
Jan 17, 2009 | GE JE1540 Microwave Oven
GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
Frigidaire FMV156EM Microwave Oven Logo
44 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
