Question about Proform XP 580 Trainer Treadmill
Incline is at bottom and will not move -- i need info to troubleshoot
I also need to adjust the belt which is shifted right and cannot find the hexkey and the manual does not list a size so i'll need to buy one but again, i need to know size.
    Top Expert:
  • Proform Master
  • 12,223 Answers
See the video and proceed according.
go and download the manual www.fitness.manualsonline.com
see the number the hexkey is 6 mms.
God bless you
Posted on Dec 10, 2012
Golds gym treadmill 420 belt will not move but panel works and elevated.
hi Mary.
If you flip on the switch, set the speed and nothing happens, your treadmill is an unhappy camper. Troubleshooting involves putting on your inspector hat and taking a tour of the belt. You may have to proceed to the console if that doesn't solve the matter. Belt Tension If the belt is too tight, it could cause enough tension that the motor can't turn the belt. This is most likely the cause of your belt not moving if you recently adjusted the belt tension due to slippage. Lift the edge of the belt. If you can't raise it at least 2 to 3 inches off the walking deck, the belt is too tight. Follow the directions in your owner's manual for loosening the belt. You will need an Allen wrench to loosen the rear roller adjustment bolts.Belt CenteringA treadmill belt can shift to the right or left over time. If it shifts enough, this may cause the belt to stop moving. Stand at the back end of your machine and inspect the belt. If it has shifted, you will need to center it by turning the rear roller adjustment bolts. These bolts adjust both the tension and the centering of the belt. Follow the instructions in your owner's manual that explain which of the two bolts you need to tighten or loosen to shift the belt back to the center.Console WiresHorizon Fitness recommends checking the console wiring if your treadmill belt doesn't move. The console wire connects to the main wire that runs down the inside of the treadmill upright to the motor board. Make sure the connection between the two wires is secure. The connectors usually snap into each other. Disconnect and reconnect the wires. Make sure the wire that runs through the upright isn't pinched or twisted.Additional Options If the troubleshooting does not get the belt running again, you may have a tight motor belt or a bad motor. You will need to remove the motor hood to access these parts of your machine. If your treadmill is still under warranty, contact the manufacturer for a professional repair. You may void the warranty if you attempt to work on the motor yourself.or read up some more at this link. Golds gym treadmill 420 belt will not move Google Search
Dec 12, 2017 | Exercise & Fitness
How do I adjust the walking belt on my treadmill, it's going to the left?
belts always move to the highest or tightest point . to adjust move one adjusting screw while the belt is running and you will see the belt move across the roller to the highest/ tightest point
adjust the screw until you get it to run in the proper position
May 14, 2015 | Sportcraft TX 4.9 Model 4041 Walking Belt
Tunturi c60 crosstrainer no longer picks up heart rate from belt and only intermittently from bar sensors any advice would be welcome.
follow this steps and fix it. God bless you
1) Reset /Off switch after 5 minutes if the the same had been tripped
2 Leave the safety key in the console, if the elevation is not adjusting or not change during Ifit, or videos are playing. Press the buttons for incline motor and pull out the safety key, while incline is moving. Re-insert again the Key after few seconds.
3 Turn the adjustment bolts on bottom rear by 1/4 counterclockwise, with allen tools.Tes the belt pulling up in each side. Lifting the belt 3 to 4 inches off the treadmill indicates a proper tension. Repeat the adjustment in case if necessary. 4 Wipe down the heart rate sensor. if not produce any accurate reading. Dry the sensor and try again
Sep 23, 2013 | Exercise & Fitness
Acd3 treadmill belt wont move
hi There.
How to Fix Treadmill Belt That Won Move
or this one.
Acd3 treadmill belt wont move Google Search
Dec 16, 2017 | Exercise & Fitness
Reebok z8 feels like its on an incline even when it's on zero incline
1) readjust the speed sensor, clean it and tight the wires connector well
2) see the block diagram.
3) RUN the software calibration for diagnose, troubleshooting , fix it
4) lube the gear and shift elevation motor.
5) adjust the POT, a little and see if you have a better improve.
6) see the diagram, and proceed
God bless you
Jul 09, 2012 | Reebok Exercise & Fitness
Moves forward fine, but creeps when put in reverse. when on incline doesn't wasnt to go backwards at all on incline. Havent tried to fix. the linkage is ok, it has hydrolic fluid no leakage noted any...
Try adjusting the main drive belt from engine to transmission. Sometimes the tension is good enough to go forward, but when shifted into reverse the tension on the belt slackens.
I hope this will give you a direction to look in.
Jun 13, 2011 | Cub Cadet Garden
I have the Incline Trainer X7i. i lost the manual. the belt is tracking to the left and rubbing the side. how do i adjust the tracking to get it back to center?\r\nthank you,
Find the allen key that came with the treadmill. It is used to assemble and adjust the treadmill.
Locate the 2 adjustment screws at the rear of the machine. If the belt is shifting to the left, tighten the left screw (turn clockwise) and the same if the belt goes to the right, tighten the right.
Only turn the screw 1/2 turn and move the belt manually to shift the belt. If it requires more, turn another 1/4 turn, very little adjustment may be required to straighten the belt. Once the belt stops rubbing, start the machine running slowly (1-2 mph) and observe the belt FROM DIRECTLY BEHIND THE MACHINE. Carefully adjust the rear roller till the belt is as close to center as possible making small adjustments, 1/8-1/4 turn clockwise of the adjustment screws.
Dec 15, 2010 | Nordic Track Exercise & Fitness
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Proform XP 580 Trainer Treadmill Logo
71 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
