Question about Stokke Xplory Stroller
Repairing its just handel and heels fixing, its mainor, no need replacements, or no any broken.., just i pulled out the handel scro, and i cant pull in it back, so if any one knows where i have to take it to repairing centers, thank u, 07983734877 dave
The Handel on the oven door has pulled off. How do you repair it?
You have an oven in your car? I can see listening to Handel on the MP3 player, but not in the oven. This is a car repair forum
Sep 27, 2017 | Cars & Trucks
My 2009 altima s driver's side door wont open from inside or outside thought door was frozen shut so pulled handle hard to try and open now cant open door
You will need to take inside door panel loose which is a little hard with door shut but it can be done and probably replace door Handel if the Handel it's self is not broke it's most likely just a little plastic clip that holds the rod to the lock
Feb 03, 2015 | 2009 Nissan Altima
How can I get a patent leather heel that is broken in the middle repaired in uk
Take it to a cobbler or cordwainer. There is a plastic or metal form that the patent leather is applied to. They can fix this forcyou.
Jul 01, 2014 | Bandolino Clothing Accessories
Hood release not working
it sounds like your hood is broken. you need to see if it is broken at the hood or inside the van. you need to pull off the kick panel it might have some screws in it. pull it off and look AT THE HANDEL SEE IF THE CABLE IS ATACHED. IF NOT TAKE A PARE OF PILLERS AND PULL ON THE CABLE. IF THE CABLE IS ATACHED THEN YOU HAVE TO TRY TO UNLOCK THE HOOD FROM UNDER THE VAN BY REACHING UP BEHIND THE RADATER AND FEEL IF THE CABLE AND TRY TO PULL THE CABLE RELACE. YOU MAY HAVE TO JACK UP THE VAN AND PUT IT ON JACK STANDS.
Jun 07, 2014 | 2000 Ford Windstar
Does Steve Madden fix the shoes (one broken heel and some out of shining stones) for free?
Stuff like that happens in dreams! You can take them to a shoe repair shop and get them fixed -especially the heel.
Feb 27, 2013 | Clothing Accessories
Blue light stays on
Lift handel and pull wall plug. Replace plug and insert Kcup and pull handel down firmly. It is rest now.
Feb 01, 2013 | Keurig Elite B40 Coffee Maker
Parking brake cable broke, 94 chevy s10 stuck, how do you release emergency brake and do i fix it
If it broke it should have released itself, the system is a simple cabel pully system, if its broken the cable cant have the tension to keep the brake engadged. if you want to release the handel pull the release and physicaly move the pedal.
Feb 22, 2010 | 1994 Chevrolet S-10
Driver side door wont open.solution on opening the door
This is usually caused by a broke plastic retaining clip.the inside handel should have a insert covering a screw pop out the insert and remove the screw. If there is no rod atached to the handel (broke clip) locate the rod in the door (a metal coat hanger works good) pull on the rod towards the front of the door and it should open.Replace the clip or sometimes the handel itself breaks needing replaced.
Hope you get a handel on it!!
Oct 23, 2009 | 1993 Honda Accord
BROKEN REAR DOOR HANDEL AN WINDOW WONT GO DOWN!
using small hook tools and tack pullers shaped like mini wonder bars, you can remove the door panel. once removed, you can fish around on the bottom middle of the door and pull the cable to unlatch the door.
Apr 14, 2009 | 2001 Toyota Sequoia
Stokke Xplory Stroller Logo
Top Stokke Baby Gear Experts
Dorel UK
Dorel UK
ray gallant
Are you a Stokke Baby Gear Expert? Answer questions, earn points and help others
