Question about Homelite Lr5000t Generators
Hi, do you still have a manual for a Homelite LR5000T Generator? I just got one today from my wife's aunt and could really use a manual.
I just bought a used Homelite LR5000T Generator from my wife's aunt; it hasn't run in 10 years, and I would really like an owner's manual for it. I've never had a generator before, and could use some tips for this one. Thanks. Alan Wismer, Lake Odessa, Michigan
3 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: have inherited a homelite generator-
Yes, this generator supports 220 volt. The grade of oil advertised for this generator is 10W30, 4-cycle.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 12, 2011
heatman101
  • 43501 Answers
SOURCE: Our Homelite model 5500 generator
The problem when that happens is usually a loss of residual magnetism...by flashing the generator you can recharge the permanent magnets, and then the generator will work again.
Generator Flashing
This link gives one way to do it.. there are others if your google it...look a few posts down to find the procedure...
heatman101
Posted on Jun 08, 2011
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
Sep 25, 2015 | Electrical Supplies
Generator output plugs don`t work
If you don't see a reset then you may have to replace a diode or voltage rectifier inside your unit.
Nov 29, 2013 | Homelite Lr5000t Generators
Why won't my Homelite 720 watt Generator start?
hi am elie hawzi i have generator 720wat homeliet had to run wer can i put 2 storc oil in my generator pleas do you have any adia haw can i leave the generator run stridaway thanks for fixya
Jun 28, 2012 | Electrical Supplies
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
I was just given my aunt's janome sewing machine
I would really suggest that you start with this website www.sewing.about.com, there is so much really good general information on sewing, sewing machines, threading up, trouble shooting, using the right sized needle and quality thread and it is all free.
I have found a pdf file of the manual on line ftp://ftp.drivehq.com/ click on the link saying "RX18S instructions", it will take a while to load as its 17MB.
Jul 06, 2011 | Janome 4612 Sewing Machine
Have inherited a homelite generator- LR5000T what grade of oil does it take. Also, does it support 220 volt equipment? Equipment draws less than 15 Amps.
Handie Andie
Apr 12, 2011 | Homelite Garden
Ive got a homelite 720 watts generator and after a month from my purchase it wont start at all. i asked the dealer and they told me that the ic inside of the genset is busted. i told them if they have...
Please list your model number when posting and I might have found part number for you.
Go to homelite.com service and support, find parts, parts locator, model # if you cannot find model number go to product line, homelite, then select generator, without model number you will have dozens of generators to look at.
Jul 09, 2017 | Homelite Garden
Homelite 6000 Generator running rough, now won't start
Sounds like the engine is not getting enough fuel. Two possible problems:
1) I know this is a dumb question, but did you turn the fuel back on?
2) If the answer to question 1 is yes, then the small fuel filter inbetween the gas tank and carburetor probably has hardened. The inside of the fuel filter is a piece of foam and it is really common for the in line fuel filters to harden when no fuel is present and cause a clog in the fuel line. Try replacing the inline fuel filter and life should be good!
Jan 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Lr5000t Generators Logo
139 people viewed this question
Top Homelite Electrical Supplies Experts
wadingriver
wadingriver
obsteiner
John Trevino
Are you a Homelite Electrical Supply Expert? Answer questions, earn points and help others
