Question about Sewing Machines
Singer cam gear
Remove and install cam gear
  • Stephen Labash
    Stephen Labash Dec 14, 2012
    Singer Fashion Mate 247 Thanks
  • Sewing Machines Master
  • 1,564 Answers
Make and model of the machine would help us help you.
Posted on Dec 10, 2012
  • 2 more comments
  • Stephen Labash
    siner fashion mate 247
  • Stephen Labash
    singer
  • Stephen Labash
    Stephen Labash Jan 30, 2013
    I could not find a cam gear for 247 but i bought one for 248 and had to cut off 1/4 inch off shaft. Seems to be working OK.
  • sylviaivie Jan 30, 2013
    So you got it timed alright. Good! Congrats.
My singer 227 m was a gift i accidently took the bobbin out now dont know how to put back in also need the settings they need to be on please cuz the top thread is reallyy loose
If the upper thread tension is off, most likely it is threaded incorrectly or it is not seated in the tension disks. Remove the upper thread, RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point between high & low number to start and then tweak it from there.
A manual for your machine would be a tremendous help.
Instruction Manual Singer 227
SINGER Installing Front Load Bobbin Tutorial
Be sure to keep your machine clean and oiled--ONLY fresh, good quality sewing machine oil or liquid Tri-Flow Synthetic Lube from the hardware store. Open the top lid, the side over the needle bar and the bobbin area. Slowly rock the handwheel and apply ONLY 1-2 drops every place where metal rubs against metal. AVOID belts, plastic gears, cams. Be sure to move selector dials and levers and oil those metal mechanisms too. Doing this every 40 hours of sewing will keep your machine happy and healthy. Also, remember to change out the needles frequently--every 8 hours of use.
Jan 21, 2017 | Singer Sewing Machines
Stuck cam on singer 322
It's difficult to tell from the picture I found, but if you can take the top off, oil the mechanism riding on the cam and work it back & forth. Usually, it will free itself. This is a sign it needs the old lubricants removed, and replaced with quality ones that won't gum up in the future. A good repair shop has safe chemicals and experience to replace the lubricants.
Feb 08, 2015 | Singer Sewing Machines
Supply of new stitch cog for Bernina 830 Record
I don't know what a stitch cog is by your definition but I suspect that you may be referring to the cam stack worm gear, part # 310 007 03. These gears are available, however those produced and sold as after market parts online have ranged from bad to very bad. I would suggest that you find an OEM part (not a reproduction) that are still available from time to time on EBAY etc.
Changing the gear is not as straight forward as it may look. The proper replacement requires: 1. removal of the cam stack without damaging the machine parts, 2. removal and installation of the new gear with the correct alignment of the individual cams, 3. installation of the cam stack and pattern indicator without axial play, 4. correct parabola timing of the main-shaft worm wheel and cam stack gear, 5. synchronization of the zigzag and automatic cam parabolas, 6. pattern indicator timing, 7. checking and adjusting the automatic needle position. SewTechnical Home
Jun 14, 2014 | Bernina Sewing Machines
Singer stylist 7258, will only pick up bobbin on one side when doing zigzag stitch
try using a washable stablizer or interfacing.
if that doesn't help then it's possible that a gear or cam may be worn enough to cause the machine zig zag not to work properly
Mar 27, 2012 | Singer 7258 Sewing Machine
Singer 7469 will not zigzag
it's possible that a gear or inside cam could be worn or broke, the machine needs to be serviced
Mar 08, 2012 | Singer 7469Q Computerized Sewing Machine
My hook gear has gone bad, I have singer sewing machine model # 834, I need help with how to take the parts off and replace them
http://www.sewingpartsonline.com/singer-834-sewing-machine-parts.aspx
Follow this link, click on the hook gear parts, and you will see a link to a video showing how to install these gears. I was able to follow this video and replace the gears on my old machine. For me it was do-able, but moderately difficult. If you think you're up to it, go for it. Replacing all for gears a t once will cost $50. (Singer 834).
Sep 16, 2010 | Sewing Machines
Hi, Have broken a gear on a Singer 527. The gear is in the middle of the shaft that drives the bobbin, and is there to drive another gear going to the foot feed cam. Can you help please with part number...
You can get the bottom gear very easily even on ebay or from most sewing machine shops, if you email me I can attach full instructions to retime but remind me of your model.
drivewithken@blueyonder.co.uk.
Mar 07, 2010 | Sewing Machines
Singer Tiny Serger: Motor runs but machine
pull the 4 bottom rubber feet out and remove screws hidden in holes. Lift main body of serger up. you will see the gears. Probably drive gear on motor shaft got hot and slid on motor shaft.
Dec 10, 2009 | Singer Tiny Serger TS380
Singer 2210/replaced gear/now needle bobbing cam out of sync
look here:
http://www.vacsew.com/repair/singer-600-timing.html
Apr 24, 2009 | Singer Sewing Machines
Replacing broken gears on Singer Touch & Sew Model 648
Remove the plastic faceplate from the front of the machine. There is a Singer logo button that you will have to pop out to release it, and then the lever nobs to get around to get it off. You can then access the allen screw on the top gear.
Remove all the set screws on both the top and bottom gears on the vertical shaft. Put them in a safe place.
The vertical shaft sits directly below the horizontal shaft, but there is some space between them and wiggle room to do the following. If the shaft does not slip down easily, use a small diameter rod or screwdriver to gently tap the vertical shaft downward until the top gear slips off the end. Remove the gear.
Mar 09, 2009 | Singer Sewing Machines
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
