Question about Cobra 29 LTD CB Radio
How to fix power meter light - Cobra 29 LTD CB Radio
  • 37 Answers
Take the cover off of the speaker side of the radio. Locate the small wheat lamp that is sitting in a rubber grommet on the back of the meter. Pull the lamp out. Cut the wires close to the lamp. Attach a 12v bulb (available from radio shack). polarity is not an issue. Use tape or heat shrink to insulate the connections. Very Simple. Do not be intimidated.
Posted on Oct 29, 2013
Fix headlights
Hi Tony:
Basic answer is that there can be 2 problems;
1) The bulbs are no good. Test with continuity meter or jumper wire from battery.
2) There is no power getting to the bulb. Test with voltage meter at the socket.
If there is no power getting to the lights you have to trouble shoot by checking for power at the fuses, light switch, and the wires to the lights.
Patience and logic.
You'll find it.
Sep 10, 2015 | Cars & Trucks
No power and cracked display is it related?
Dale, If your charger starts flashing very fast, or no light is coming on at all, something is wrong. No light coming on, could mean it does not get any power. But it also could mean the battery has died.
If you have a multi meter, you could test what voltage the battery has. Most batteries are 3,7 or 7,2 volt. when you use a multimeter, the reading in DC should be something like 3,9 or 7,5. On the meter the outage should be a few percent higher than what is printed on the battery. As soon as the meter indicates a voltage just a little (or worse a lot) under the printed value, the battery must be replaced.
Apr 25, 2014 | Nikon 1 J1 Digital Camera
How to fix cobra 1000 gtl Powers up,meters stuck, no rx just static, All lights work, A mic will Key the on the air light,
have you checked the voltages inside the radio?If you have to much or to little it will not work properly.
Jan 19, 2014 | Cobra 2000 Gtl / 1000 Rf Pwr / Signal...
How to fix trunk light on eclipse spyder gt
Could be a bad ground. Could also be a bad connection at the switch or power source. The connection in the switch could be just good enough to power the meter but not the bulb.
Jul 25, 2012 | Mitsubishi Cars & Trucks
I accidentally hooked up the battery, reversing the polarity. I corrected the screw-up, but now the radio and interior lights will not come on. Fuses look good. any suggestions on fixing the radio &...
Ouch! Okay, do you have a volt meter? If so you need to check the voltage at your fuse box to make sure that you are getting power to fuse panel If you are getting power to the panel, then you have to diagnose the power issue from the fuse panel to the radio and dome lights. All the lights not working? The radio may have an in-line fuse as well. If you don't have a volt meter, go get one.
Jan 25, 2011 | 2001 Mazda MPV
Headlight and meter lights
this problem can be solved by checking the wiring of the bike, all you need to do, with the help of the multimeter turn on the bike and light and check with the multi meter, are you getting the power, else you need to the change the wiring,, this will surely solve your problem,, thank u,, plz rate me,,,,
Jun 01, 2009 | 1985 Yamaha XJ 700 S Maxim
01 Focus 2.0 split port engine. Service engine light on!
uplug air metering sensor car should run almost normal but will set check eng, light
Nov 29, 2008 | 2001 Ford Focus
2003 Impala - mystery problem???
you have something thats staying on with power when you shut the car off,first check all lights glove apartment,underhood,in trunk ,just because ther closed doesnt mean the light is off,check your car at night it might help to see the lights,if not another way is to take a multi meter to the battery and while some holds the meter pull out fuses in your fus box one at a time to see when the meter makes a change,this will help you to narrow down whats staying on and draining the power from the battery,if this helps please give me a fix ya vote
Jul 14, 2008 | 2003 Chevrolet Impala
Flashing amber light, no battery recognition or power meter
Bad DC IN (probably after last repair)
One side of the DC Jack is not getting ground connection.
This happens when one of the negative leads are not connected. Simple fix for skilled tech
Feb 17, 2008 | Dell Inspiron 2200 Notebook
SLR light meter
Hmmm well its getting power.... surely the lens is on correctly. Since the camera seems to be working, one option is to get a hand-held light meter.
May 19, 2007 | Vivitar V4000 Zoom 35mm SLR Camera
Cobra 29 LTD CB Radio Logo
67 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
