Question about Element ELCHW402 40 in. LCD HDTV
My tv will power up but no picture or sound
The led light on the bottom of tv will turn from red to blue.
  • 26 Answers
It sounds like the main board is bad
Posted on Dec 10, 2012
2 Suggested Answers
  • 608 Answers
SOURCE: element elchs321----tv cuts off on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors. That crackling sound is the capacitors burning out.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
When the power is off, I can see the red light on bottom left, but when I turn it on why do I get nothing, no picture, sound or anything?
The red light indicates power is getting to your TV and it is in "standby". When you turn your TV on, an open internal fuse or power supply failure may be preventing normal operation.
Aug 28, 2015 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
No sound, no picture
If by catscan sound you mean a high pitched whine? That usually indicates that the power section has had a part fail. The capacitors on the main board will cause this. You can take it to the shop but get an estimate first as the repair cost can be close to replacement as the prices keep falling. The repair parts are pretty cheap but the labour isn't.
Jul 24, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
No Picture, Power LED goes from Blue to Red
It sounds like the red LED is signifying a fault. Check your manual (or ring the manufacturer's support line) to find out what the red LED means. If it does in fact signify a fault, file a fault with the manufacturer and return it to them under warranty (if you still have it).
Sep 06, 2007 | Insignia IS-LCDTV32 32 in. Television
Element ELCHW402 40 in. LCD HDTV Logo
265 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
