Question about Dell Inspiron N7010 Laptop Core I3 2.4ghz, 640gb, 4096mb, Dvdrw, Win
Remove pc 3.5mm jack
Sounds come on and off from my pc because my 3mm jack is broken..i would have to slap the bottom left of my keyboard for the sound to come back on...and now my pc has no sound and it thinks there is a headphone plugged it (speaker properties, general tab, jack information, green circle next to -left panel 3.5mm jack)
  • 22 Answers
Sounds like there is a loos conetion for your hard speakers witch will cause this some times i wold say take it to a spechlist and have them fix it
Posted on Apr 14, 2014
Moisture absorbing ball struck in headphone port of hp laptop. How to remove it? please help me.
Tip: Try with a desoldering pump. Make a small rubber gasket of chewing gum etc. Tighten the tip against the 3,5mm Jack with the gasket in place. Maybe the vacuum sucks the ball out
SOLDER ****** DESOLDERING PUMP DESOLDER REMOVAL VACUUM
Aug 11, 2013 | HP Computers & Internet
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
How to replace keyboard on sony vgn-nr498e, broken left hand shift key, i need to replace entire keyboard
If you have the new keyboard, look at the bottom and locate the screw sockets. On the laptop at the bottom, match and locate the approximate location of where each screws are mounted. Remove only those screw. On some laptops, you might need to remove the keyboard top frame - if they are mounted with screws, remove them as well. Some laptops have a small picture or symbol of a keyboard for each screw that needs to be removed on the bottom of the laptop.
Dec 09, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
What jack is compatible to laptop using shure
You have to connect the unbalanced output (the 6.3mm jack) to the laptop's line in (or mic with setting the rec level at very low settings) 3.5mm jack. In details the wiring should be as follows:
6,3mm jack shield to 3,5mm jack shield
6,3mm jack ring to 3,5mm jack shield
6,3mm jack tip to 3,5mm jack tip and ring
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 12, 2010 | Shure PGX14 Wireless Guitar/Bass System...
How do I access the DC Power Jack on a Dell Latitude C510?
I assume you mean to replace it. You need to take all the screws out of the bottom,check under the battery too. Remove the hard drive,keyboard bezel keyboard, Remove all the screws under the keyboard except the cpu heat sink. Seperate the halfs & you should be able to remove the board. Now you can solder a new jack in. Good luck!
Mar 15, 2010 | Dell Latitude C510 Notebook
Speakers don't turn back on after removing the heaphones
The way you described convinced me that your audio driver is OK, but the sound can be heard through the headphone only. If this is the case then you have a mechanical failure (metal fatigue) on the head phone jack assembly.
I consists of two DPDT switches ganged together in a small housing with have 3mm jack on it. The leaf spring contacts failed to make after the headphone plug is detached. Only skilled technician can remove it from the PCB then sold an new one in.
Jun 03, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Trying to get sound from computer to m-audio studio pro 3 speakers
You need a cable with 3,5mm jack in the computer end, and 2xPHONO in the other. Like this:
May 07, 2009 | HP Pavilion A6332F Desktop PC
Saab 95 Aero
Jack up o/s of car and support on stand
Remove front o/s wheel
remove bottom engine covers from inside o/s wheel arch and also bottom engine cover(plastic)
support engine with jack; remove yolk engine mount ( on belt side)
Put 1/2" extension drive into top of belt tensioner and pull toward engine - you can now put a 3mm drill bit or allen key into hole at side of tensioner to hold in position.
remove serpentine belt
from underneath car, use 8mm ( I think) allen key to remove centre bolt from belt tensioner
It should now come off of the car
fitting is the reverse of the above
hope it helps
Nov 08, 2008 | 1999 Saab 9-5
Easynote r1004 d.c. input socket broken
You really have to completely remove the motherboard from the case to do this. If you cannot find the exact replacement jack (not called socket in parts catalogues) you can just run the wires out of the case to whatever jack that will accomodate your adaptor. If you do not have the remove/replace procedures and still want to tackle this then make sure that you keep track of where EACH screw goes as they do vary in size/threads and pay careful attention to the ribbon connectors that connect to the keyboard, display and touchpad. The bottom of the laptop has little icons that relate to what the screw releases (like a keyboard icon) and even the screw designations molded into the bottom case. If this is a maiden voyage into laptop repair then research or you will learn the hard way. An ESD strap is essential here and all drives/battery/PC modules removed. Good luck. ~Steve
Oct 19, 2008 | Samsung V20 XVC 2400 Notebook
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Dell Inspiron N7010 Laptop Core I3 2.4ghz, 640gb, 4096mb, Dvdrw, Win Logo
107 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
