Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Basic cable connections using rear coxial connection
I hooked the cable up through the coxial connection on the back of the tv and the picture keeps coming up not clear, but snowy looking and fuzzy..... i checked the cable outside to make sure the cable was not damaged and it checked out good... i put a dvd in the dvd player to make sure the tv was not messed up, but again the picture came out perfect... i bought a brand new cable for the cable but still the picture came out bad when i wanted to watch regular tv shows...i auto programed in air mode and cable mode but the picture is coming out bad as in not good.....it worked just fine a couple of days ago but today for some reason its not co-operating like its supposed to....can you help me out, thanks Melvin.....
    Problem Solver:
  • 12 Answers
Better call your cable tv provider.it seems that the problem is out of your premises
Posted on Jan 13, 2009
I am trying to connect dish network as a remote Tv (a second tv) on my panosonic P46c2. My old tv connected with a coxial cable into the "antenna cable in". How do I see the picture on this tv?...
You may need to run a channel scan or add the channels manually in your TV menu. If you need assistance please e-mail me at: daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Apr 20, 2011 | Panasonic TCP46S2 TV
Trying to hook up magnavoc Dv220mw9 to my cable box & tv
Sorry, looks like it didn't load right with that last solution. Let me try again....
CONNECTING VCR
If this doesn't get it let me know I will try to walk you through it further.
Good Luck....
Jan 13, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
My sega genisis doent work
on the back of the genesis there is a place where you would hook up rf adaptor and then the other end would plug up to the coxial connection on the back of the tv or the a/v cables would plug into the video and audio jacks on your tv. Depends on what came with your system.
May 03, 2009 | Video Game Consoles & Games
Using FIOS HD DRV STB with a VCR
Okay let me make sure I understand.. Looking at the back of your STB and VCR do you see an (IN) and (OUT) coxial connection?
If so, you can use the coxial connections to obtain your desired results.
I hope this solution is helpful. Please remember to rate thsi solution.
Feb 12, 2009 | Televison & Video
Go video model dv-241 hook up to make vhs to work
There are a fews ways of accomplishing this.
It sounds like you may reversed your cable connections. Lets try these steps.
On the back of your cable box and your Go video VCR/DVD there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from Comcast to the (IN) connection on the back of the cable box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the cable box.
Step 3. Connect the other end to the (IN) connection on the back of your GO Video box..
Step 4. Connect one end of another spare coxial cable to the (OUT) connection on the back of your Go Video Box.
Step 5. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful.
Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
How do i connect my basic cable to my dvd/vcr player?
Is there on the back that say in then another out to tv
that the way it use to be I hope this works
Feb 08, 2009 | Philips Magnavox DVD/VCR Dual Player
Connect to Converter Box
On the back of your converter box and TV/VCR there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from the antenna to the (IN) connection on the back of the converter box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the convert box.
Step 3. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful. Please take a moment to rate tis solution.
Jan 19, 2009 | Panasonic Televison & Video
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
Connections
Without the manual !!
1)VCR INPUT:: [Cable_antenna In] the coxial screws on from "output" of cable box or ( airwave )antenna.
2) VCR output:: connect another coxial into input of TV. You should be able to keep all the other wires connected from SONY theater system.
note:: your VCR has a switch for VCR\TV. When u have a VHS tape playing a movie & switch from VCR to TV, you will see the channel that is on the VCR not the cable box\ antenna input.
example:Cable channel is on Ch.122, & your TV must be set to Ch.3 to view cable.If your VCR is set to Ch/5 you may not see that Ch.122.You will still be able to see your VHS tape when u place the VCR\TV switch back to VCR.
I am going to share wt.u a $100,000,000.00 trick:put any ch.on cable box.Switch VCR\TV to TV,change channel ON VHS tuner.When u come to the [picture] that the cable box is on,Then that is the Ch.u can see cable ON the VHS.
U owe me!!
Jun 08, 2008 | LG 42LC2D 42 in. LCD HDTV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
