Question about Dell Dimension 2400 PC Desktop
How to remove starburnsoftware.com from my computer
  • Dell Master
  • 27,725 Answers
Click start control panel Add or Remove Programs or Uninstall a Program this may vary depending on your operating system scroll to see if the program is listed select uninstall or it might have its own uninstaller. click start all programs look for program select it and see if it has the uninstall capability. click start type in starburnsoftware press enter it should take you to the program it might be a shot cut right click see what options are available ther might be an option to go to the program.
Hope this helps.
Posted on Dec 10, 2012
I CAN'T SEEM TO BURN A CD FROM MY WINDOW MEDIA I KEEP GETTING ERROR STATING THAT SOMETHING HAS BEEN CHANGED
Download and install a burning program called ''Starburn.'' It is free, awesome, and never fails like Windows burner frequently does. I actually uninstalled a fully paid for Nero Burning program because I wanted Starburn instead. I use it on every computer I own and it has never let me down. (Super easy to use too). // Ps... Make sure you get it directly from the www.starburnsoftware.com web site. Other ''free download'' sites can be dangerous.
Dec 31, 2014 | HP Computers & Internet
How to remove trovi from my computer
Open Internet Explorer, go Tools -> Manage Add-ons -> Toolbars and Extensions. Here, look for Trovi Toolbar, Trovi and similar entries, and click Remove. Now open IE -> Tools -> Internet Option -> General tab. Enter Google or other address to make it the default start page.
Jun 16, 2014 | Microsoft Internet Explorer 9
How to remove ask. com from my computer?
run any malware removal tool and remove unnecessary programs from the computer. reset internet explorer.
Open run box (Win key+ R), type inetcpl.cpl, click ok, go to advance tab, click reset, and click again reset then close.
It may help you if there is any add-on causing this issue.
These days there many advertising apps get downloaded on the computer automatically during the installation of the core software. e.g GARMIN.
May 10, 2014 | HP Computers & Internet
How do i remove www.inbox.com from my computer
Removing www.inbox.com
Click "Start" and select "Control Panel" from the menu.
Click "Add or Remove Programs" or "Uninstall a Program." Wait for the list of programs installed on your computer.
Click "Inbox Toolbar" in the list of programs. Click "Remove" or "Uninstall/Change."
Click "Yes" to confirm that you want to remove the toolbar from your computer.
Wait for the toolbar to be removed and click "OK" when prompted
If www.inbox.com is not in the programs list /remove programs ( it probably isn't there!)
Go to windows menu bar, Tools.. Manage Add-Ons.. Click on: Search Providers..
You will probably find several search providers, highlight InBox.Com it will activate your options (found at the bottom of the page)... click on ''disable suggestions'' which means it will no longer operate but will be available if you decide to use it later or click REMOVE to eliminate it altogether..
When you have done that check the box which says ''Prevent programs from suggesting changes to my default search provider''
Also check to verify what your search provider is (it will read active) and whether it's the default.
Dec 10, 2013 | Computers & Internet
How to install ram on an hp 9470m
Before removing the service cover, follow these steps:
1. Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the
computer on, and then shut it down through the operating system.
2. Disconnect the power from the computer by unplugging the power cord from the computer.
3. Disconnect all external devices from the computer.
4. Remove the battery
5. Remove the hard drive cover
Remove the service cover:
1. Loosen the 5 captive Phillips screws (1) that secure the cover to the computer.
2. Tilt the door up from the computer slightly (2), and then lift the cover up and off the computer (3).
Remove the memory module:
1. Spread the retaining tabs on each side of the memory module slot to release the memory module.
See pages 47 and 48 for more detailed directions and pictures.
http://h20565.www2.hp.com/portal/site/hpsc/template.BINARYPORTLET/public/kb/docDisplay/resource.process/?spf_p.tpst=kbDocDisplay_ws_BI&spf_p.rid_kbDocDisplay=docDisplayResURL&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.rst_kbDocDisplay=wsrp-resourceState%3DdocId%253Demr_na-c03909856-1%257CdocLocale%253Den_US&javax.portlet.endCacheTok=com.vignette.cachetoken
If you need further help, I’m available over the phone at https://www.6ya.com/expert/benjamin_29adbb94bfb43281
Mar 20, 2013 | Computers & Internet
Hard disk removal
On a desktop computer WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the power lead from the power in put on the computer remove the side panels on on our computer you will see 4 screws 2 either side unscrew these then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten) http://www.ehow.com/video_4978913_install-internal-hard-drive.html YouTube video install a second ide hard drive http://www.fonerbooks.com/laptop_1.htm laptop hard drive http://www.ehow.com/how_5451891_remove-hard-drive-ibm-notebook.html Hope this helps. http://compreviews.about.com/library/weekly/aa-diy-motherboard.htm http://compreviews.about.com/od/tutorials/ss/DIYMB.htm How To Replace HP Pavilion Desktop Hard Drive http://www.youtube.com/watch?v=5Cn1N04q804 Hope this helps.
Dec 31, 2012 | HP Pavilion Elite m9426f Desktop
Removing harddrive from case
What type of computer laptop or desktop ?
Dec 29, 2012 | Western Digital Caviar WD800BB 80 GB Hard...
How to remove hardrive from computer
i was unable to locate your spicific computer i hope this will guide you
http://www.youtube.com/watch?v=qzFB-URV6EM
Replacing a hard drive in a Compaq Presario SR5010NX PC
laptop hard drive
Hope this helps.
Nov 25, 2012 | Compaq Presario 5240 (353200-003) PC...
Trojans on laptop cannot access anything on computer
Trojan virus is a malicious computer program designed to infect a PC by changing its desktop or removing the important data files.
Follow this article to remove trojans from your computer:-how to remove trojans from your computer
Try having a free virus scan by experts at http://www.vtechsquad.com/virus-removal
Sep 14, 2012 | Lenovo ThinkPad Edge E430 Laptop Computer
Mhow do you remove superfish from my computer
If you're having trouble removing software or 'adware' from your computer you might have decent luck with Adaware, freeware from Lavasoft.
http://www.lavasoft.com/
I've used it over the years to remove/detect thousands of files on hundreds of computers that otherwise couldn't be moved or detected.
Best of luck William
Mar 23, 2011 | AVAST Software Avast Free Antivirus
Dell Dimension 2400 PC Desktop Logo
21 people viewed this question
Alun Cox
