Question about EliteGroup ECS A535 Notebook
Can't find wirelless device
Have an exclamation point in my device manager; I believe this is my wireless adapted. How do I install update drivers that works in Win 7?
    New Friend:
  • 13 Answers
Go to device manager, right click on device, then go to properties.....Then click on the Details tab. The from the drop down list, select Hardware ID.
Post that long hardware ID here.
Posted on Dec 10, 2012
  • 1 more comment
  • Phil Dec 10, 2012
    Hi Chris,Handware Id value USB\UNKNOWN
  • Phil Dec 10, 2012
    After reading FAQ on ECS's website concerning wireless card not working I discovered the wireless card is AM303W. The software used is WLAN
  • Chris Dec 10, 2012
    it's a USB wireless card? If not, then that is not what that device is that says USB\Uknown
Utstarcom um100c software for windows 7
for your download click htt
This device will work on win7, no problem. You'll need the install disc or the software.
UM100 win7 64bit
1.Double-click the quicklinkmobile.exe application from cricket. It will unpack a folder with the installation files in the same folder the quicklinkmobile.exe app is residing.
2.Go in that folder and click on start.exe, then click on install quick link mobile. Go through the normal setup as you normally would.
3.Once it finishes installing, connect your UM100 UTStarcom modem on a free USB Port. Don't open the Cricket Wireless application just yet.
4. Go to start menu, right click on Computer and select properties. Then click on device manager on the left. You will find the UM100 modem has an exclamation point on it.
5.Right click it and select update driver. Select "Browse mycomputer for driver" Option at the bottom. Click on Browse to select a driver from a location, then navigate to your root drive (usually C: and sometimes D then to Program Files (x86)/Cricket/Quick Link Mobile/System
6.Make sure you navigate to this cricket wireless installation folder. It should be in C:\Program Files (x86)\Cricket\QuickLink Mobile\System. Once you find it click ok. Make sure "Include subfolders" is selected under it. Click on "next" and now it will install the driver.
7. After it installs, it will create two more Unknown devices with exclamation points. Wait a couple of minutes for the system to finish up installing that one before you continue with this instructions.
8. Now repeat steps 5 and 6 above for each of the two unknown devices until there are no more devices with exclamation points in device manager.
9. Now open Up Cricket Wireless application on your desktop or start menu, and continue with the normal modem activation of the wizard that appears. That's it! It will now detect the modem and activate it. Allowing you to use it.
10. Go and find whoever said you couldn't use this modem on 64-bit systems and punch them in the face.
11. Call me so I can punch them in the face again.
12. Enjoy your newly installed UTStarcom UM100 cricket modem on your 64 bit system. Ask Cricket to update their website with this information. Punch them in the face too for the sake of completeness
Read more: http://www.cricketusers.com/cricket-mobile-broadband-devices/20339-utstarcom-um100c.html#ixzz22FHP7OMr
hope this helps
Jul 22, 2012 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
There is a yellow exclaimation on my network adapter in device manager
This not necessarily cause for alarm. You can try to reinstall the driver for the device to see if that clears out the exclamation mark and, most cases, it will.
The exclamation mark simply means that Windows has found some sort of problem with the device. Double-click the adapter and see what the Device Manager's status says about it. This can, generally, point you in the right direction on what is wrong.
If reinstalling the driver doesn't work then post what the Device Manager status is for the device.
Jul 04, 2012 | Acer 91.AB370.001 Network Adapter
I have a linksys WRT5G2 wireless and I upgraded my computer from vista to windows 7 and now my linksys doent work what can i do
I'm sure the router still works fine. You probably just need a driver for your wireless adapter.
Open up your device manager. If you don't know how to do this..it's laid out here:
http://pcsupport.about.com/od/windows7/ht/device-manager-cp-windows-7.htm
Look under "Network Adapters" and see if there are any yellow exclamation points next to anything. If there is, you probably need a driver for that adapter. You will need to provide the make/model of the computer if you can not locate and install the driver yourself.
If there are no problems with the drivers..you may need to reconfigure your wireless network settings.
This site gives you a good rundown of how to do that.
http://forevergeeks.com/how-to-connect-to-a-wireless-access-point-in-windows-7
Aug 24, 2011 | Linksys WRT54G2 Wireless Router
My friend has an acer an she is trying to put the network adapter that were originaly on the computer becaus her boyfriend deleted it
If I am understanding you. Then all that was done. Was to remove the drivers for them. So they won't show up. However they will appear with exclamation point in device manager.
(start/run/devmgmt.msc) then we just need to reinstall the drivers. to help you identify the needed driver check here http://support.acer.com/us/en/default.aspx. they can be stored on a flash drive and select update driver and point to the flash drive for the needed files.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Acer Computers & Internet
Network adopter,pls download device driver for window vista "dell"
go to device manager ( click on the windows circle and search for device manager ) ans find under which adapter you have issues ( generally you ll find exclamation point or red x mark next to it ) . Right click on that adapter and check for enable option ( if red x) Select update software if its an exclamation point , select update automatically ping me for any more info .
Jul 24, 2011 | Dell Computers & Internet
Not detected wireless
I will do my best to help you with this concern.
1. go to Device Manager and check all drivers if nothing is missing...if yellow exclamation point.. found-update specified driver
2. In device manager under network adapter is where you check the driver if there's no icon on it like exclamation point..
3. if all drivers are updated-tried to connect to the network.
4. if this is a laptop. make sure the radio button/ wireless switch is on.. in connecting the network.
5. if this is a desktop, make sure the wireless adapter is working fine.
6. if still unable to connect try to contact your service provider and make sure you have the right WEP/ network key to connect to your network.
I hope this will help you.
May 30, 2011 | Microsoft Windows Vista Home Premium...
D-Link DFE-528TX has been installed but the problem is the hardware manager has an exclamation point besides D-Link DFE-528TX which tell the D-Link DFE-528TX has not been working properly. First D-Link...
hi
first check of the pci port is woking try to transfer to other pci port and uninstall your d-link driver and install it again, if still doesn't work uninstall again and install it by right clicking your d-link, to do this
right click on computer click manage and choose device manager and you can see your d-link device with exclamation point. right click on it and update driver guide it where your driver is and install.
thanks
Nov 26, 2010 | D-Link DFE-528TX Network Adapter
Hi, I have an Acer TravelMate 2420. And every time I install windows XP it, for some reason, cannot find the wireless network hardware. And installing the driver seems to be useless as well. Any suggestion...
Try right-clicking on My Computer, go to Manage, then go into Device Manager. Inside Device Manager's list, do you see any devices with a yellow exclamation point? If not, expand the "Network adapters" section and see what's listed. It's possible that there is no wireless adapter in that laptop (unless you're sure there is one). Another possibility is that the wireless adapter is there, but not functional, faulty, or just plain broken. If the device is there and working, it should show up in Device Manager as an installed device; if it's there, but not working, it'll show up with an exclamation point. If it's not in the list at all, it's probably broken or the laptop doesn't have a wireless card.
Jul 18, 2009 | Acer TravelMate 270XV Notebook
Replaced hard drive on HP dv4000. Install XP Pro and drivers from recovery disk. Updated to SP3. Do not have 1394 net adapter listed in network connections. Connected external hard drive to firewire port...
I would check in device manager (control panel) and see if the network card is listed. It probably has a yellow exclamation point next to it. If there is an exclamation point there, then right click the card and click uninstall. Next, using your wifi to access the internet, download the latest network card driver from the PC vendor website / Motherboard vendor site / discrete network card site.
Install the network card driver and you should be back in business.
Jul 09, 2009 | HP A6795A#0D1 Network Adapter
Yellow exclamation mark over the network adapter- 6To4 adapter. When I uninstalled and restarted my computer the adapter was not reinstalled. Sony laptop with Vista 32 OS.
the yellow exclamation mark indicates that the driver is not installed... run the installation disk once again install the adapter .. if unable to install with cd then, right click on the adapter from device manager and click update driver and manually update the driver ... it should work
Apr 16, 2009 | Packard Bell 1580509280 Network Adapter
Computers & Internet Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
