Question about Dell Mms 5650 5.1 Surround Sound Home Theater 6 Speaker System Subwoofer Mms5650
Fuse keeps blowing even when not operating anything with sound; hooked up to computer
Brake light fuse blows
Hi Anonymous, obviously you have a dead short, hook one lead of an ohm meter up to the out bound clip of the blown fuse. Clip the other lead to a sharp pointed scribe and start stabbing the wire from the fuse it keeps blowing untill the ohm meter quits reading zero and reads infinity and there or very close by is your short. For a wiring diagram go to: http://www.stcharlesharleydavidson.com/OEMpartfinder.htm#
enter your year and model then scroll to the " W " for wiring diagram. Good luck
Apr 13, 2014 | Harley Davidson FLHX Street Glide...
04 nissan titan will not do anything
Something is shorting out, disconnect your battery for 30 min and remove the fuse that keeps blowing, reconnect battery WITHOUT putting the fuse in and see if it will start, if it does then you need to take your radio out and look for wiring faults..
Jun 21, 2013 | Cars & Trucks
2002 chevy 1500 keeps blowing #1 injector fuse
IF YOU HAVE CKED FOR A SHORT THEN MOST LIKELY YOU HAVE A BAD INJECTOR. YOU CAN UNPLUG ONE INJECTOR AT A TIME UNTIL IT STOPS BLOWING FUSES OR YOU CAN TAKE IT TO A REPUTABLE TECH WHO CAN HOOK IT UP TO A SCAN TOOL AND IT SHOULD SHOW THE BAD INJECTOR.
Dec 11, 2012 | 2002 Chevrolet Silverado 1500
Battery fuse keeps blowing
that is the problem . who ever hooked up the fan it is cut into something. I bet if you umhook the fan you will stop blowing fuses
Nov 23, 2012 | 1997 Infiniti.5 Q45
20A ACC/cig fuse, 40A fan fuse (AC) keeps blowing on 05 Sebring.
Disconnect the cigar lighter and see if the short goes away, I will bet it does.
Aug 09, 2012 | Chrysler Sebring Cars & Trucks
Yes my fuse for my wipers keeps blowing and my wipers turn on when i plug fuse in even know the wipers are turned off.
The power distribution box in the engine compartment # 6 , 30 amp mini - fuse , front wiper motor , front wiper relay , front washer pump , FEM ( also # 7 , 25 amp mini - fuse , rear wiper etc. ) The owners manual shows to disconnect your battery cables before servicing anything in the PD BOX
your relay could be shorted which makes the fuse keep blowing
Sep 05, 2011 | 2001 Ford Windstar
How come it blows 30 amp atc fuse instantly even with the system off
check connections are hooked up properly if it blowin the fuse with it off sounds like something is really wrong on inside get it checked out
Jun 04, 2010 | Kicker KX200.2 Car Audio Amplifier
When key is turned to on position, keeps blowing 30 amp fuse
It sounds like you have a short in some wiresets. Check the wires directly connected to the ignition. If this persists, without any problems with wires, I suggest checking the amperage and voltage on your battery to make sure they are at operational levels. Anything over 14.8 volts and you start to fry electrical components and... blow fuses.
Mar 19, 2010 | 1995 Toyota Corolla
Tail light fuse keeps blowing
where do you have the power wire for stereo hooked or hooked into?
Jan 18, 2009 | 2001 Lexus IS 300
Z-5300 blown fuse
When fuses blow theres a problem, now how it blows help you find out where the problem is, If the fuse flashes and turns black the second you turn it on or plug it in there is a massive short in the power supply, If it blows but is clear the surge was not a dead short but a overload, Either way best to run it down to the shop and get it looked at
Feb 14, 2008 | Logitech Z-5300e Surround Sound System...
Dell Mms 5650 5.1 Surround Sound Home Theater 6 Speaker System Subwoofer Mms5650 Logo
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
