Front loader will wash but not drain and spin
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 10, 2012
  • pcolleen9
    pcolleen9 Dec 11, 2012
    Please tellme where Iwould find this.....I have looked on the back panel . It is a Gibson heavy duty
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
  • 572 Answers
SOURCE: front loader frigidaire wont spin or drain final
in the bottom panel theres a coin trap
Posted on Feb 06, 2010
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Door locked light flashes.
After turning off at power point, then restarting unit will commence but light starts flashing again and machine stops
Posted on Jul 04, 2010
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Posted on Dec 28, 2010
  • 106 Answers
SOURCE: Front Loader LG Inverter 7.5kg model WM-12330 FB
Have you already check your drain clean out? If it's not draining, you'll need to manually drain the washer, via the small hose that pulls out, once it is drained you can unscrew the large clean out filter, and see if anything is caught up in that area.
If all that is clear, it's most likely, you'll need a new drain motor. Also, did you notice if your getting a "OE" error code on the display?
Posted on Mar 04, 2011
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
It is not spinning now.
Depending on the make and model top loader or front loader, the most common issues are the lid switch or door lock safety interlock, or the pump filter is clogged and need cleaned. Let me know what machine you have and I can go from there.
Jan 27, 2011 | Washing Machines
My top washer loader would not drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Nov 04, 2010 | Frigidaire ATF6000ES Front Load Washer
My tub won't drain correctly, we followed the maual and still not draining fully from tub. I have a maytag front loader.
heatman101
Sep 15, 2010 | Maytag Washing Machines
My samsung vrt front loader will not drain or spin and showing nd code
heatman101
Aug 28, 2010 | Samsung Washing Machines
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
