Question about Tascam 2488 Portastudio Multitrack Recorder System
I just received my Tascam 2488 Neo recorder. I did not get the mic to work. I pluged it in to the back, but I am not sure if the phantom power is on or off when the button is down??
    Novelist:
  • 189 Answers
When the button is down phantom power is on (for the first four inputs only... A to D... which are XLR or 1/4" ... the others don't have phantom power).
Make sure that the trim pot for the input is turned up. You should see the meters moving for the stereo bus in the LCD screen when using the mic even if the input isn't yet assigned to a track (and hear it assuming your monitors or stereo system is set up already and the master fader is turned up).
Posted on Jan 13, 2009
Hi im new to using the effect send on my tascam 2488 neo. How do i set the connections? how dose it work?
I think if you had the manual you would know the answers.
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 05, 2011 | Tascam 2488 Portastudio Multitrack...
Can i use my own electric guitar stomp box to record onto a tascam 2488 neo without miking an amp?
Yes, you should be able to go direct into the recording input if your guitar has a preamp in it and the 2488 may have adequate gain to even accept the input from a passive guitar.
Nov 30, 2010 | Tascam 2488mkii 24 Track Recording...
Mic/line inputs Yamaha md8 Multitrack recorder not working
A little testing is required to nail this down.
1) Will a standard mic work in either channel?
2) Will a line level source work in either channel?
It is likely that either the power supply for the phantom power or the supply for the mic pre-amp IC has failed or the IC itself has failed. If a standard mic works, then it is the phantom power supply that is faulty.
I am not aware of any service manual available other than from Yamaha directly (for a price of course...)
If you can update this with the test results, perhaps we can walk through this repair.
Dan
May 12, 2010 | Tascam 2488 Portastudio Multitrack...
Recently purchased the Tascam 2488 Neo Digital/Microphone Effects
Assuming you have your mic plugged in properly and all is working well save for this one issue, do as follows: press the SELECT button on the track/channel which has the mic on it. Then press the SEND button over to the right of all the tracks. The button is right under the EQ button. After you press the SEND button, a screen opens up and you can send reverb to that channel/track...as much as you want. I hope this helps.
Feb 17, 2010 | Tascam 2488 Portastudio Multitrack...
Anybody can help me with operation of Tascam 2488 neo. I find the manual trips me up and a simple manual would be great if available
Here's a 2488 DVD tutorial. You may even find it elsewhere at a better price. It is of great help.
http://www.amazon.com/Tascam-2488-Video-Training-Tutorial/dp/B000FTJ5UC/ref=sr_1_1?ie=UTF8&s=dvd&qid=1284348097&sr=8-1
Dec 26, 2009 | Tascam 2488 Portastudio Multitrack...
TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
I want to sing over disk soundtrack.I have tascam neo.Please tell me how to do that,Thank you
The best way to accomplish this would involve ripping the sountrack from disk first using your PC to create a wav file and then importing the resulting stereo wav file into a pair of tracks on the 2488 NEO.
The process for ripping would depend on whatever software you use to rip from the CD (lots of free ones available out there) and the process to import a stereo wave into the 2488 NEO would be detailed in your 2488 manual on pages 81 and 81.
Hope this helps.
bd.
Oct 07, 2009 | Tascam 2488 Portastudio Multitrack...
Neo drums ?
No the neo does not have the built-in drum patterns/drum machine like the origial grey 2488 did. It was abandoned for the 2488 MkII which was the intermediate model and hasn't reappeared. I create drum patterns either using an external machine recorded in real time to a track on the my 2488 or create a drum pattern on the PC which I save as a mono wav and import to a track on the 2488.
Jun 03, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
176 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
