Question about Kenmore Dehumidifiers
My Kenmore dehumidifier 50501 has started icing up. I have had it for 2 years. There is nothing about ice forming on it in the troubleshooting section of the manual. Is there anything I can do myself
It has worked fine up until about a month ago when it started freezing up. I turned it off and let the ice melt. I turned it back on and I saw the ice had started to come back so I turned it off.
SOURCE: Kenmore dehumidifier model 5230
have same problem of frosting. tried all combinations of humidity and speed settings. its still cold in basement so i fired up a small space heater. after 5 days still no results. seperate humidistat reads 83%. help please.
Posted on May 19, 2008
  • 121 Answers
SOURCE: Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
SOURCE: everything works, but does not collect water
Can I replace the freon? Or do I just by a new dehumidifier?
Posted on Jul 04, 2008
SOURCE: Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Posted on Mar 28, 2009
SOURCE: dehumidifier freezes up
Most dehumidifiers need warmer air to work properly. The temperature in a basement is usually 60 - 65F; too cool for standard models. You could buy a "basement" dehumidifier. They're designed to work at lower temperatures; some as low as 40 F. Costs are about the same as a standard dehumidifier; you just have to find it.
For a cheap fix, try this; it seems to be working for me.
Since the condensate coil (the one icing up) is cold, the air entering it is too cool and the condensate frosts up the coil. Additional condensate freezes to the frost and before you know it, you've got a block of ice. Since the air coming out of the front is very warm take a large piece of cardboard around 6' x 3') and form a V. Placed it in front of the dehumidifier so it channels some of the warm air back to the rear where it warms the moist air up before it hits the cooling fins. It's helped keep the ice down.
If you want something attractive, any screen that redirects some of the air back to the rear will work. Just leave the top open so it doesn't get too hot and the some of the drier air gets out into the room.
Posted on Jun 22, 2009
Kenmore model 580.54351800 ices up quickly, doesn't defrost, and as a result doesn't dehumidify. Bad thermistor?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Sep 12, 2011 | Kenmore 54701 Dehumidifier
Why is ice forming on the top of the dehumidifier ?
Sometimes when they run extended periods of time the outter case can get very cold also...with no air moving over the outer case the condensation can freeze there....
This is a tip that I wrote that will help to understand it better...
Dehumidifier is Freezing up and not working http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 04, 2010 | Kenmore 54501 Dehumidifier
Ice forming on the to
Usually this happens for one of two reasons: 1) there is a problem with the refrigerant and/or compressor (like a little leak of refrigerant)
2) the room that the compressor is in is too cool (below the operating range of the dehumidifier)
If the unit is under warranty, call for service if you know the room is above the minimum operating temp. If it is a problem with the refrigerant, they will probably replace the unit.
I hope this helps.
(we have an LG dehumidifier and had to have it replaced when it was less than a year old - it was icing up in the summer. It still iced up in the winter (at times due to cold in the basement).)
May 01, 2010 | LG LHD45EL Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
Running, but no water coming out. Is forming ice
Your machine has a sealed system leak and is low on freon. Read your owners manual and there should be a 5 year sealed system warranty. If so you will need your purchase receipt and call an authorized LG dealer for an exchange.
Oct 09, 2009 | LG LHD45EL Dehumidifier
the unit has a sealed system leak and needs pro repair call sears or a&e at 800-905-9505 for service
Apr 28, 2008 | Kenmore 5230 Dehumidifier
Dehumidifiers Logo
77 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
