Question about Toshiba E-Studio 3040c Color Copier
How to mount hdd on e studio 3040c f101_9 error code
Security hdd had f106 code reloaded hdd software and now have f101_9 error code with mean we have a unmounted hdd... looking for service code to mount hdd. please help!!!
2 Suggested Answers
SOURCE: Error code in E studio 150
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
Posted on Feb 20, 2008
Toshiba e206l error code F106 sub code 5
this is either a hard drive error in which case you need to replace and reload firmware Or this is a communication failure in which case checking all the boards and connectors may fix it or you have a bad board.
Jul 09, 2015 | Toshiba Office Equipment & Supplies
What does error code CE 40 mean on a Toshiba e-studio 3040c and how can it be fixed
U need to see it happen on which process unit, then check the main charger unit and developer material is enough...
Apr 07, 2015 | Toshiba E-Studio 3040c Color Copier,...
HDD mount failure on Toshiba 351c copier
"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Jul 30, 2014 | Toshiba E-studio 351c Color...
F900 error code, how to fix
F900 is Model Information Error
Perform SRAM-Re-Initialize Support
If cannot, perform Key FROM to SRAM
Jan 24, 2014 | Toshiba E-Studio 3040c Color Copier
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
Toshiba E-Studio 3040c Color Copier Logo
53 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
