Question about HP LaserJet 4650 Color Printer
4650dtn HP printer black printer cartridge won't release...how do I release this cartridge?
  • HP Master
  • 7,627 Answers
SOURCE: cannot get the printer to accept the new HP black cartridge
On my officejet 5510, I decided that the printer was toast and decided to throw it out and buy a new one. After making that decision, I decided to pound on top of it it a few times. Guess what??? You guessed it.....it reset itself and started back working. That was about 6 weeks ago and I haven't had a problem since. I have since turned it off and on many times, and it works like a charm. GO FIGURE!! (I only recommend this to those who have given up and are planning to trash it anyway).
Posted on Feb 04, 2008
emonsi
  • 22 Answers
SOURCE: HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
Posted on Sep 07, 2009
Ezrahite
  • 2632 Answers
SOURCE: Have HP F4480 printer, replaced
Welcome to Fixya. If you have a paper jam error message you can use the link below and follow the steps on how to clear paper jam error. Sometime you just need to clean the rollers and it will be fixed.
HP F4480 Paper Jam Fix
If you have questions please let me know. Thanks for using Fixya
Posted on Mar 31, 2011
BaronVonNuke
  • 1915 Answers
SOURCE: i have an hp 2600n
Regardless of whether you have printer set to print in black and white, these models will not function without usuable cartridges in all slots.
Posted on May 14, 2011
SOURCE: My HP Officejet 6500 Wireless
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
Posted on Jun 20, 2011
HP Photosmart C4140 error message won't go away Remove and check color cartridge. I have done this and unplugged, checked both color and black cartridges...won't go away.
hey, sometimes there are faulty cartridges. i use to got some brand new and original from the shop and not working.. so try it with some old cartridge if you have.. you can also try to remove the cartridge and clean/wipe the contacts on the cartridge side and on the printer side (turn of the printer for safety)
Sep 18, 2011 | HP Officejet 5510 All-In-One Thermal...
Will 27 black and 28 tri-colour cartridge work on a D1560 hp deskjet
HP 21 black and HP 22 tricolor cartridges are the cartridges compatible with HP DESKJET D1560.HP 27 and 28 won't work with your printer because they won't get recognized by the machine.It will only give you an error message like incompatible cartridges.
Jul 21, 2011 | HP D1560 Deskjet Printer InkJet
My pc says printer in back up mode
that means either the black or tricolor cartridge ran out of ink and it's currently utilizing only one cartridge.let say you ran out of blank ink but tricolor cartridge is still good you can still print or make a copy using only one cartridge but the quality won't be that good
May 31, 2011 | HP DeskJet F4180 Inkjet Color All-In-One...
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
I have an hp 2600n and a ibook 4g. yellow cartridge is empty and orange light is blinking. have printer settings to black & white, but won't print. help!
May 14, 2011 | HP Color LaserJet 2600n Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Wrong colour cartridges
Did you try the genuine HP cartridge? Maybe you should try first the original Ink Cartridge.
Nov 15, 2007 | HP Color LaserJet 4650DTN Printer
HP LaserJet 4650 Color Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
