Question about Refrigerators
Freezer on my daewoo erf-336m fridge freezer not working
  • 183 Answers
SOURCE: need help
With this model it suffers with the evaporator freezing up, try to defrost overnight with the doors open, restart the following day and it should start to work ok within 24hrs. Regards Advisor
Posted on Sep 01, 2007
fridgetech
  • 473 Answers
SOURCE: Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
Posted on Oct 05, 2007
skrbin
  • 121 Answers
SOURCE: daewoo fr581 freezer not freezing
Behind fridge probably have a ventilator,check is it work,clean a gas cooler(radiator) from dust with a dry brush.If ventilator is not work change it.
Posted on Jul 04, 2009
projdoc
  • 2236 Answers
SOURCE: My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
SOURCE: fridge freezer leaking
there should be a drain pan under in unit. it could be missalinged or the drain tube may have a hole in it. mice are good about this
Posted on May 22, 2010
How to identify why my Daewoo ERF-364MNL fridge freezer is warm
This is a fairly common problem with most Frost free Fridge freezers. The system relies on regular automatic defrosting, and if there is a fault in that, the cooling cycle is seriously affected.
The problem could be as simple as a blocked defrost water drain tube, or more complicated such as a failed de-frost heater, defrost timer, or drain tray heater.
To check and repair any of them, is quite an involved process which involves stripping a lot of trim, and other parts just to get to them.
I would suggest that you get a qualified Refrigeration Engineer to repair it.
I hope this helps?
Feb 08, 2016 | Daewoo Refrigerators
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
I have a Daewoo ERF-334M fridge/freezer and the auto-defrost has stopped working. The evaporator gets covered in ice within about 3 weeks from it being manually defrosted. I've checked the resistance...
More than likely if your fridge has a bi metal, or a defrost timer, its one of those two issues. Leaning more towards the bi metal. If the bi metal is encased in ice and is reading more than 0 ohms its your bi metal. (small round sick that sits on the tubing) Your heater should be reading around 25 ohms or something like that. it should be fine. If it does not have a bi metal it works on a thermistor and then you more than likely have a electrical control board issue that not forcing the fridge into defrost. Lmk if you need more help!
Aug 04, 2013 | Refrigerators
Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
Apr 28, 2012 | Daewoo Freezers
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Aug 15, 2011 | Daewoo ERF336MB Freezer
My daewoo fridge freezer model erf 340m not cooling at all
low pressure switch could be bad, or low on coolant. call service repair man
Dec 12, 2010 | Freezers
Fridge freezer leaking
May 22, 2010 | Daewoo Refrigerators
I have a Electrolux Frdige Freezer Model ERF 2830.
check appliance blog .com and type in your make/model,sometimes there are fixes on there
Nov 01, 2009 | Refrigerators
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
