Konica 7030 copier: works good exept no power on ADF
Plug is connected, even replaced ADF still the same . is it main board
  • Norman  J Weimar Jr
    Norman J Weimar Jr May 11, 2010
    Have you check the power supply fuse. Does anything come on?
  • sam gerban
    sam gerban May 11, 2010
    what is the problem?
  • 29 Answers
In this particular machine it is very likely that the PSU (Power Supply Unit) has blown. You could also try another power cord/power socket.
Posted on Aug 18, 2009
Error solve ?
MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 23, 2016 | Konica Minolta Bizhub C360 Color Copier...
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Data imaging solution on c7000pro bizhub
7A00 Description Failed to arrive home
• Error of the imaging carriage home sensor. • Error of the carriage motor. Causes • Controller board (CTLB) • Imaging carriage home sensor (PS15) • Flatbed motor (M4) Remedy 1 Turn OFF/ON the main power switch. 2 Check CTLB for proper connection and correct as necessary. 3 Check PS15 and M4 for proper connection and correct as necessary. 4 Replace Flatbed unit. 5 Replace ADF unit. 6 Replace CTLB.
Dec 10, 2014 | Konica Minolta bizhub Office Equipment &...
Cant find phone connection on my konica 7030
My Guess.
On the rear were printer cables power cable enter, there shoiuld be either a plug hole for the cable, it might have a plastic cover hiding it.
Jan 28, 2013 | Konica Minolta Office Equipment & Supplies
ADF of Minolta C450 is not working
the sensor switch were you put the paper in detects the paper is there if the switch is working the adf board is fualty or the cable between the machine and adf broke from all the open and closeing after that the board in the copier were the cable plug in may be faulty swop the around with annother machine if avalible.
Mar 14, 2012 | Konica Minolta bizhub C450P Laser Printer
Error c620
SC620 B Communication error between BICU and ADF The BICU does not receive a response from the ADF main board for 4 seconds or more. The BICU receives a break signal from the ADF main board. • Poor connection between the BICU and ADF main board (DF connector) • ADF main board defective • BICU defective
Apr 07, 2010 | Ricoh Aficio 2020D Copier
On a sharp SF-2020.. I get a U5 code with 01 subcode...
u5 indicates the ADF can't communicate, make sure the ADF is pluged into the copier. MAKE SURE TO UNPLUG COPIER BEFORE CKECKING ADF PLUG. If all is good then main board is bad.
Feb 25, 2009 | Sharp SF 2020 Copier
Konica 7030 will not power on
How about the wall outlet? Try another one or plug something else in to test the outlet. Also, look on the back of the copier by the power cord in put for a breaker that may be triped...
Oct 02, 2008 | Konica Minolta Office Equipment & Supplies
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
jasbo
jasbo
