Front load washer stuck on final spin
I inadvertently took out a load of wash before final spin. next day went to load the washer and it's stuck on final spin. i've unplugged the machine overnight, threw in some huge wetted beach towels, pushed start/pause to attempt to reset...nada!! also, a few months ago the LED lights of the program i use failed to go out completely - just dimmed instead. help
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
  • 156 Answers
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Posted on Feb 28, 2008
SOURCE: F D/L and F11 error codes
I have a Kenmore (Whirlpool) front loader He3t that begin having the same problem after 2 years. I researched the problem and tried everything. The door lock mech. and all wiring was fine. Finally I stumbled upon a way to clear the error. (It still shows up once in a while.) The following has worked for me CONSISTENTLY about 25 times.
1) Remove top washer cover.
2) Disconnect the connector for the door switch on the control box.
3) Reach around and push any cycle button (normal, delicate, etc.)
4) Now hit the Cancel button.
5) Reconnect the door switch connector to the control box.
6) Reach around and push any button again. The clicking stops for me.
7) Replace the washer cover and use normally.
Hope this works for someone else!
There must be something getting latched up in the control board. And it gets reset.
Posted on Nov 11, 2008
SOURCE: Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
blueextc3221
  • 15935 Answers
SOURCE: INDESIT WIXXL 146 washing machine ( please help
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 18, 2010
There is a something rubbing in between the drum and the outer shell. Not so much in ccw as opposed to cw.
Hi David Cisco - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. This is not a DIY job, so I strongly suggest contacting a professional to move forward accurately to properly assist with the repairs.
Feb 12, 2013 | Frigidaire FTF530FS Front Load Washer
Wssh300g2ww won't drain
Tip this on its side and look from underneath. You should be able to see better what is holding it on there. Every washer is different and everyone makes you swear when working on it.
Jan 31, 2013 | GE WSXH208A Front Load Washer
I have a Frigidaire LTF530FS Front Load Washing Machine. It stopped draining and spinning. The drain pump had an underwire from a bra stuck in it. We removed that and cleaned the pump. Hooked everything...
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Since you hear a humming noise, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 28, 2012 | Frigidaire FTF530FS Front Load Washer
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
Frigidaire front load washer code error E20
Hi, this error is caused by a clogged drain filter located under the drum assembly.
If your machine is stuck on the drain sequence or you read error code E20, the filter basket is probably clogged:
You will need a pair of slip-joint pliers and a Phillips head screwdriver.
Before beginning any work, make sure to unplug the machine from the electrical outlet.
**Note: It may be easier to perform this task with the washer lying on its side; therefore it may be necessary to disconnect the water lines from the machine.
1: Take off the front kick plate (two screws at the bottom of the machine).
3: There is a black accordion hose with two clamps.
2: Have a towel ready to catch the water that leaks.
4: Remove the clamps at each end to access the filter basket.
5: Stick your hand inside the hose and remove the plastic filter basket (it will probably be clogged with hair, lint, fabric).
6: Thoroughly clean the filter basket and remove all debris from the inside of the black accordion hose.
7: Replace the filter basket.
8: Reattach the black accordion hose at both ends.
9: Secure the clamps at each end of the hose.
10: Wipe up any water that may have spilled inside the machine.
11: Reattach the front kick plate with the two screws removed earlier.
12: Reconnect all hoses before plugging in the machine to the electrical outlet.
Thank you.
Jun 06, 2012 | Frigidaire ATF6000ES Front Load Washer
My lid lock button is stuck and will not unlock....when i 1st went to the washer it was on spin and lid lock and i pressed the start button which is suppose to unlock this lide but that has not...
That happened to me once. I just unplugged the machine for a few mins and it released the lock when I plugged it back in. I've got my fingers crossed that it doesn't happen again.
Aug 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't do final spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore 3.5 HE front load washer went haywire, doesn't work now..
Yes - the ECU is to blame, and is a common failure with this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 43042 Front Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
