Question about Bosch KGU32124 Bottom Freezer Refrigerator
Freezer stoped fridge is fine freezer just deforest it self and wont refreeze
Hi our DA99-01220A Samsung Fridge Freezer builds ice up at base of freezer. Door seal is fine.its not over filled. Any suggestions? Guide doesn't give helps from Samsung
The drain line for the auto defrosting mechanism is clogged. The melted ice water collects on bottom of freezer and then refreezes over. Clear the line.
Oct 10, 2015 | Samsung Refrigerators
Deforst fridge and freezer
Wrong section and dont understand your problem.
May 26, 2014 | Video Game Consoles & Games
Indesit fridge/freezer starting & stoping
The compressor is supposed to start & stop, it wont run all the time.
Nov 22, 2013 | Amana ABB1927DE Bottom Freezer...
Freezer thaws and refreezes
HI.DO BASICS FIRST .CLEAN CONDENSER UNIT FIRST THOROUGHLY.INTERMITENT FAULT IS ALWAYS A BIT DIFFICULT TO DIAGNOSE.TRY IT IF OK U HAVE CRACKED IT BUT IF SAME THEN C WEATHER THE MOTOR AND CON/UNIT IS WARM WHEN DEFROSTING IF COLD IT COUD BE A LAZY DEFROST TIMER OR T/STAT THEN HEATER AND FAN.GOOD LUCK ALI
Jul 09, 2012 | GE GSH25JFR Side by Side Refrigerator
Ice melts then refreezes
It's staying in defrost to long. Could be a bad deforest timer or a bad defrost thermostat.
Aug 03, 2011 | Imperial Refrigerators
Refrigerator does not get cold. The freezer works fine, but the fridge only gets slightly cool.
normaly the fridge has its own thermostat to keep the tem right, if this thermostat has stoped working it will do one of two things,,, freez every thing up as it wont turn off the compressor or will just stop working as it wont turn on the compressor,,, try turning up the thermostat first,
Nov 19, 2009 | Hotpoint Refrigerators
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
I have a Conia fridge/freezer. The freezer is working fine but the fridge part is not getting cold at all.
In some cases like you have, you need to unplug the unit and let it thaw out. Store you freezer food in an ice chest or else where to keep it frozen.
If the unit has self defrost, the defrost cycle refreezes and blocks the circulation of the refrig area. Make sure all frost and water are removed before plugging the unit back in.
Mike
Jul 29, 2009 | Televison & Video
Freezer stoped two days ago!
Sears uses a nuber like this 213.25647 Can you find a number like that so I can help you?
Jun 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Bosch KGU32124 Bottom Freezer Refrigerator Logo
37 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
