Question about Shanling SCD-T200
SACD plays erratically - Shanling SCD-T200
  • Jose Desentis Dec 10, 2012
    It begins playing wright, but eventually, once the unit became warmer, it reads the SACD's erratically.
Sacd 1000 lazer alignment
There is no alingments to laser assembly. If it found faulty, must be repalced.
May 20, 2012 | Philips SACD1000 CD Player
Recently had the amp repaired. Set up used to play sacd fine but since repair the sub offer does not play on sacd. Plays on everything else fine. Can only assume a setting has been changed in the avr200...
It's in the manual.
The ".1" in 5.1 is for the subwoofer. Recheck the analog cable for that channel as it comes from the unidentified SACD player. If you had mentioned the make and model of it that would have been helpful.
Jun 27, 2011 | Arcam AVR-200
The sacd player was working fine. But now will not play them. Using optical for sound hdmi for video. Played around with different settings but will only read the cd portion of the sacd. Any ideas? like i...
Your PS3 may actually be playing the SACD layer but if you're listering through optical you're not going to get any better sound quality than CD.
For stereo SACD quality you can use the analog outputs; for multichannel SACD quality you'll need to use HDMI.
See the PS3 SACD FAQ.
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
What is the best way to attach a Sony SCD CE595 CD player SACD to a Denon AVR 2105 Receiver. I thought the optical input would be best but according to a web posting, toslink does not support SACD
That is correct. Digital connections through some models of SACD players are via "firewire", otherwise it is analog output. There are no optical connections.
The shortest pair of RCA cables, or even component video cable as an alternative will work.
Dec 12, 2009 | Denon AVR-2105 Receiver
I like the look and price of the Marantz SR 6003 receiver, my only question being whether it suppports DSD data output from a SACD player like the ONKYO like the OPPO DV-980h. In other words can it receive...
Downloaded the user manual for the Marantz SR 6003 A/V Receiver. In this it stated that if a SACD player was connected to the SR 6003 with an HDMI interface earlier than 1.2 then the digital data from the SACD could not be transferred over the HDMI cable to the SR 6003. This implies, but does not confirm, that if a SACD player does provide a digital output on an HDMI 1.3 interface, then SACD audio data can be transmitted to the SR 6003 and, presumably, decoded and converted to 6 analogue streams which are then amplified and deleivered to the (6) analogue output terminals.
I'm fairly sure that the native DSD data from the SACD has to be converted to PCM before transmission over the HDMI interface which is better than nothing. What I was hoping for though was for the data to be transferred in DSD and converted in the SR 6003 directly to analogue, avoiding two intermediate conversions. This ideal solution can be done by only a few SACD/ A/V Receiver combinations, which is silly considering that it is also the simplest. One example, which has made a big impression amongst high fi enthusiasts, is the OPPO DV-980H Universal DVD player (plays any audio or video disc and costs almost nothing) and the Integra DTC 9.8 home theatre processor.
Jan 14, 2009 | Televison & Video
Dennon 3930 dvd player unable to play sacd in 5 channels only in stereo.will play dvd-a disc in 5 channels
For DENON DVD-3930: In "setup", HDMI sound settings have to be "2-channel". Then SACD 5-channel output is enabled.
Jul 14, 2008 | Denon DVD-3910 DVD Player
No SACD output
Set the HDMI to "Stereo" from multi-channel.
Mar 26, 2008 | Denon DVD-3910 DVD Player
Shanling SCD-T200 Logo
42 people viewed this question
Top Shanling Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Shanling Audio Player and Recorder Expert? Answer questions, earn points and help others
