How to make song not to loop more than once
In my pqi joytone L801 i-pod , the song repeats means its loops again and again instead going to the next song so i need help regarding how can i make it to go to next song.
please Help me
  • Phil Betts
    Phil Betts Aug 17, 2016
    Thank you for your answer.
Annoying right? All the buttons do different things depending on whether you hold them for a long duration or short duration. To toggle between Normal Mode, Shuffle, Repeat One and Repeat All hold the + Volume button down.
Posted on Mar 21, 2009
How do i make a banded treble stitch please
  1. Yarn over hook three times, then insert hook into next stitch.
  2. Yarn over hook and draw yarn through stitch (there are five loops on the hook).
  3. Loop yarn over hook and draw through two loops (there are now four loops remaining on the hook).
  4. Yarn over hook and draw through two loops (there are now three loops remaining on the hook).
  5. Yarn over hook and draw through two loops (there are now two loops remaining on the hook).
  6. Again, loop yarn over hook and draw through the last two loops on the hook (there is now one loop remaining.)
  7. This completes one double treble crochet.
Jan 30, 2015 | PTAJ Marketing Crocheting Stitches
How to put random pqi joytone-u801 mp3 player
Hold the "+" key down when the song is in pause and you will the options - stop at the option you want.
Jan 25, 2013 | PQI JoyTone-U801 MP3 Player
Singer 2517c. When sewing, the bottom stitch is using to much thread, excessive amounts & the stitch isn't tight. I've tried all settings & have used a new bobbin. I'm at a loss......
Your description isn't very clear. When you say the "bottom stitch is using too much thread" Do you mean you see lots of loopy threads on top of the seam? Or do you mean you see loops on the bottom under the fabric? If your loops on the bottom, that means the top tension is too loose, you've not remembered to put the presser foot down, you have not threaded the top thread properly... Start by rethreading carefully with the presser foot UP. Then do a test stitch, remembering to put the presser foot down. If you still get loops underneath... tighten the tension.
If your loops are on the top of the fabric. loosen the top tension... then do a test seam... and if you still have loops loosen again and repeat. If you start to see loops on the bottom... tighten the tension a bit.
Good luck
Dec 30, 2012 | Sewing Machines
1999 lexus Trouble Codes
Well, it would seem that replacing the sensor twice would point to the ECM but not always.
Code 125 means the engine is not reaching operating temp which is needed to put the system into closed loop. Closed loop means the ECM is looking at all of the sensor readings to determine fuel trim level instead of using pre-set values. On cars built in the late 1990s closed loop is supposed to happen within a few minutes of start-up to cut down on emissions.
The code means the temp reading is below 195 degrees for too long, which is usually a faulty thermostat. Once in a while it is a faulty temp sensor.
As for the other 3 codes, there could be a problem with the wiring between the O2 sensor and the computer. And that might be expensive to find. So the dealer may be hedging their bet with the ECM replacement idea.
But that would not address the first code unless you have had the thermostat replaced and the cooling system is ok.
Jul 11, 2012 | 1999 Lexus ES 300
Por favor, describa su EUROPOWER completo Diagrama 2.500 problema:
my PQI JoyTone-U801 MP3 Player don't play songs "No_song"
Apr 07, 2011 | Audio Players & Recorders
How do you make a song to loop at the 16th bar, i.e recording on a 16/4 time signature?
16/4 is not a usual time signature, is that what you meant? if what you mean is that you want the song to loop AFTER 16 bars, in other words play the 16 bar then go back to bar 1 then you need to set the loop point at bar 17. It doesnt matter what time sig you are in, this will work. If you want to actually loop the 16th bar ONLY then you need to set the loop out point at bar 17 and the loop in point at bar 16. Hope this helps.
Feb 16, 2010 | Music
GENERAL QUESTION
I believe what Tascam means by the 'effect loop' on the 2488Mk2 is simply a send loop within the device which internal effects can be set on (vs. a the 'send loop' which exists when you send a track out the sends, through an external effect device, and then back through one the the 2488 inputs). This effect loop is sent to the stereo bus as well as the bounce sub mix.
To use the internal effects in this way you'd select a track with the 'select' button for the track (or you can do multiple tracks by repeating this process for each track one at a time). Then press the send button and on the top of the screen you'll see the effects loop. Just set your send there to 100 or so and that track will be sent to the internal effect loop and be affected by whatever single effects you have turned on. To print these tracks with effects you can either premaster or create a bounce mix. Just make sure you mute any tracks you don't want in a bounce because a bounce will record anything which is on the stereo bus.
(See page 42 in your manual for Tascam's explanation for using the single effect and page 58 for how to create a bounce submix).
Hope this helps.
bd.
Jan 26, 2009 | Tascam 2488 Portastudio Multitrack...
How???
Just connect an MP3 cable fron your player to to your computer, and go to MY COMPUTER and click on the drive that represent the MP3 player, you can delete the music files from your player.
Dec 13, 2008 | PQI Joytone U820 Digital Media Player
Problem with MP3 player-Stops after one song
On closer look (after my long road trip to test this out), I realize when you hit Browse, there's a button on the bottom titled Play All. If you select this button, the buttons mentioned above work as intended, and the Forward, Backward buttons bring you to the next or previous songs in the list.
Sep 27, 2008 | Garmin Nuvi 660 GPS Receiver
306 people viewed this question
 Grubhead
Grubhead
