Question about Solis Master 5000 Espresso Machine
Service center Brew unit will not go in all the way unless I press the lever. Coffee is not brewing properly. Waste - tamped grounds are dripping wet, all screens are wet and dark coffee barely dripping out of unit. The whole system has been cleaned including the screens and spout (dispenser). I need to know what to do and where is the nearest authorized service center near Raleigh, NC?
    Problem Solver:
  • 14 Answers
Have you cleaned the outlet behind the brew unit? It is a trapezoidal shaped small hole below the plunger window. It gets clogged easily. Squirt some water into it and above it. It should come out clean. If it's clgged the water backs up into the grounds
Posted on Feb 13, 2013
SOURCE: I have a Solis Master
I solved the problem by talking to some other location that did not charge $20 for the conversation and a solution.
REQ
Posted on Jan 07, 2009
SOURCE: coffee barely drips out. I cleaned everything. Do
How about with the basket and portafilter in place, but no coffee in the basket? Does the water flow reasonably when you turn on the pump?
Posted on Apr 28, 2009
  • 1796 Answers
SOURCE: Brewed a coffee on my
Hi!!
Make sure the steam knob is closed, if it is open, when the machine gets at brewing temperature, only hot water will be dispensed out of the steam wand. If steam knob is closed:
  • unplug unit's power cord form wall outlet,
  • open the service door and remove the drip tray and grounds container.
  • Use the brew group key that came with the unit to loosen the brew unit, then,
  • remove it and clean under warm running water.
  • Let it dry completely before returning it to the machine.
  • Place brew group on the proper position and use the key to tighten it in place,
  • replace grounds container and drip tray,
  • close service door and plug power cord back on.
Unit should be operative. A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 20, 2010
  • 1089 Answers
SOURCE: My machine will grind but no coffee is dosed.
HI
If you don't hear a click 3 times your building up fine ground coffee inside the box that the door works. Your ground is probably to fine and you are using a shiney bean which has more oils in it. Your big dial inside the bean hopper should be on 10-12 and the small knob should be turned down to the neutral position. You might for the first try turn the big dial up to 16 and see if it will work. If it doesn't your going to have to clean the grinder. This is what grinding to fine does. It cakes the grounds.
Posted on Jan 19, 2011
  • 1089 Answers
SOURCE: Solis Palazzo : turn on
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Posted on Aug 04, 2011
Waste unit is stuck and I can not remove it
The standard instructions are ... remove the waste container, water container & ground coffee container. On the front of the Brew Unit is a vertical black lever with a grey press button at bottom. Press this button and turn the lever clockwise. Then press the release catch that holds the brew unit as base and pull the brew unit. If Brew Unit is still stuck then its likely that the Unit State is not in the 'home position' and if this has occurred then its likely that that an error code would be showing. Regards
Dec 27, 2015 | Miele CVA4070 Coffee Maker
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
My Spidem Villa has stopped grinding beans when I press the button for an espresso. The automatic tamper tamps an empty chamber and then hot water comes out, but no coffee is ground or put into the...
Hi
Sorry but that doesn't make sence. The grind chamber has to be full inorder for the doser to activate, unless you have an oiley bean and it has hardened inside the doser.
Try removing the brew group. Then inside on the roof of the machine above where the brew unit sat, there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it should drop coffee. This should clear the opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
May 20, 2010 | Saeco Spidem Villa
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
HI
There is a lever on the top of the door that has a + to the back and a - to the front. Pull the lever back 1 click to the front or - side. Your putting too much coffee in the brew unit and could break the brew drive.
Nov 30, 2009 | Saeco Royal Professional Espresso Machine
Saeco Magic De Luxe type SUP012 r Water leakage into brew unit
HI
Your grind might be a little to coarse or you are not getting a full charge of coffee in the brew unit. Water is released into the drip tray when the brewing is over. If the grind is to coarse or you don't have enough coffee dossed into the brew unit, then there is more space for water and you get more water in the drip tray. Open the door and push the lever at the top center of the door towards the plus but not all the way. 1 click back from the plus(+) is fine. When the machine is grinding pull the handle toward you(smaller number). Now change the grind a little at a time, but don't make it too fine. That will cause a lot of problems later on that is hard to correct.
Jun 26, 2009 | Saeco Magic De Luxe Espresso Machine
No coffee coming out, just hot water
Two questions:
1- Is the coffee grounds wet or dry?
2- Does the spout drip water when the machine is just heating up?
If the grounds are dry then the brew chamber is not getting any water. Turn machine off, let it cool down, then remove brew unit. Behind the brew unit there is a white valve with 2 red o-rings(sometimes black), if you look closely there is a small lever between the o-rings, get a small screwdriver and gently lift lever and spring, if water came out then the problem is in the brew unit, unscrew the stainless steel screen which is under the large red O-ring on the brew unit and clean, also make sure the tube on the unit is clear.
If the hot water spout is not dripping when the machine is heating up then you're good.
May 12, 2009 | Coffee Makers & Espresso Machines
Solis Master 5000 Espresso Machine Logo
87 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
isaac johny
isaac johny
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
