Question about Samsung LTM1575W 15 in. LCD Television
Power supply I need a power supply
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Parts or boards are rarely available for sets this size and brand--they for the most part a throw away sets unless you find bad caps and can repair it yourself.
Posted on Dec 10, 2012
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
Will not power on
Try to change your power supply.
Jul 14, 2011 | Medion M3 Composer 5200 PC Desktop
I need a manual or product number for power supply power supply order #
No you don't. If you think the power supply is bad, then unplug it, unscrew it, and take it to a discount place like Fry's to simply match it. Compaq does not make its own power supplies, so they use generic ones, like everyone else does. The only thing you have to choose is how many watts you need. The original may have been rated too small if it went bad, and you many want one with more power, like 500 watts.
Jan 17, 2010 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Switching power supply ??
For your purposes there is no difference: all you need to know is the voltage your WD drive requires, and the maximum current load it needs. Any regulated DC power supply with that voltage and *at least* that current will do.
Not-so-technically, a "regular" power supply will supply power at the correct voltage by "discarding" a portion of the extra potential. A "switching" power supply will shunt and switch the extra power away, so that instead of being "lost", it is "not requested" from the uplink grid. In theory a perfect switching supply will have no losses, and therefore dissipate no waste heat (in practice there will be some losses, and cooling will be needed). The important thing, though, is that a switching power supply can deliver twice as much power as a "normal" supply, and the same power in a half as big package.
Jan 03, 2010 | Computers & Internet
Xbox 360 not powering up at all. power supply light blinks orange
An orange light is illuminated on the power supply for one of the following reasons:
* The console is turned off.
* The power supply is disconnected from the console.
* The power supply cord is not fully inserted into the power socket of the console.
* The power supply is faulty.
* The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
The power supply has several built-in safeguards to help prevent damage to either your Xbox 360 console or the power supply itself. The power supply will automatically turn off if either the current flow, the voltage, or the temperature is too high. When the power supply turns off for any of these reasons, the light on the power supply will turn from green (normal) to orange or to red, or the light will turn off. When the power supply light is green, the power supply is working correctly. What you are experiencing is an over heating issue, that may have damaged the supply.
With that being said, i would try to reset the supply by disconnecting the unit from the console, and unplugging the power supply unit from the wall socket for 5 minutes. Once the 5 minutes have passed, reconnect the unit to the console, and plug the power supply into the wall socket. If the console dose not power up, and the supply unit is still showing an orange illuminated operating light, this will confirm that the power supply unit will need to be replaced. Contact Microsoft for the correct replacement parts needed(power supply unit)
TIPS FOR PREVENTING OVERHEATING ISSUES
* Do not block any ventilation openings in the power supply.
* Do not put the power supply on a bed, on a sofa, or on any other soft surface that might block ventilation openings.
* Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
* Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
* Do not use an unlicensed accessory, such as a replacement power supply that was not manufactured by Microsoft, or any accessory that plugs in between the Xbox 360 console and the power supply.
* Plug the power supply directly into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
* If you are not sure about the reliability of an AC power outlet, power circuit, or power cabling, do not use it. Contact an electrician.
Oct 26, 2009 | Microsoft Xbox 360 Console
I get no power at all to my computor. There is
The easiest and safest way is to purchase a power supply tester. Just unplug the power supply wireing harness from the motherboard and plug it into the tester. It gives led readouts. Its around five dollars. or just simply take it to a computer shop, most will check that for free
Aug 31, 2009 | Antec SP-400 400-Watt Power Supply
Dead Computer
Is the fan of the power supply still circulating?
If not, your power supply needs replacement.
Jul 24, 2009 | Okia 420w UL Approved ATX Computer Power...
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
Power supply for gateway
This power supply has an odd form factor so just "any" power supply won't work.
Nov 11, 2007 | Computers & Internet
Samsung LTM1575W 15 in. LCD Television Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
