Question about Kenmore Dryers
796.8044 kenmore dryer not blowing heat
Drum runs but no heat , filter and vent clean fuses reset
  • 184 Answers
SOURCE: kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Posted on Apr 10, 2008
  • 32 Answers
SOURCE: Kenmore ultra fabric care dryer runs, but does not heat up
could be a thermal fuse,heating element or a heating element relay.if you pop the trim caps off of the sides of the console,and remove the 2 phillips screws in the corners and lift up console you will find a tech sheet inside.if you have a multimeter that you can check continuity with along with the tech sheet,you might be able to figure it out..good luck
Posted on Sep 29, 2008
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
  • 82 Answers
SOURCE: DLG5932 gas dryer blows its overheat fuse, after
The dryer is overheating but is not the fault of the vent. Have the technician check the operating thermistor on the exhaust behind the blower wheel. This thermistor acts as the thermostat for this dryer and if it is off will either not allow the dryer to heat or will overheat the dryer like in your case and cause the thermal fuse to blow out or trip. He should measure ohms and according to temperature and should have access to what it should measure. If the thermistor measures bad, replace thermistor. If this measures good the control board is reading the thermistor wrong and the board will need to be replaced.
Thank you
Posted on Jan 23, 2010
heatman101
  • 43501 Answers
SOURCE: Our dryer has no heat. The drum turns and we
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 28, 2010
41799980100 Kenmore Laundry Center dryer themal fuse blows
you need to clean out the dryer.the thermal fuse is a safety switch so you don't have a fire when the dryer is running to hot.blow out the vent line with a leaf blower,unplug the dryer and make sure the outside vent is clear.next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,do this once a year,your clothes will dry on time,no fires and you'll save on parts.let me know how you make out
Apr 19, 2010 | Kenmore 62802 Electric Dryer
Will dryer still run and heat if one of the thermostats (cycling[internal bias], high limit, and/or thermal cut-off) is faulty? Would it simply 'blow' the thermal fuse (that i just replaced) again?
if the thermal fuse keeps blowing it's because the dryer needs a cleanout.you need to clean out the duct that the lint filter slides into vac out the inside of dryer where the motor is and if you have a shop vac put it on blow and blow off the motor,there's alot of lint stuck inside it that the vac can't get out,you can blow the lint from the back of dryer to the front so you don't have to pull the drum to clean it.if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean out the line,i've blown out bird nests and big balls of wet lint after people told me the vent line was clear also make sure the outside vent is clear no screens or cages if there is remove them all they do is catch lint.do this once a year so you don't have a fire and you won't have to replace parts from overheating,thermal fuse is a safety that will pop if the dryer runs to hot mostly from a clogged dryer
Apr 17, 2010 | Kenmore 62882 Electric Dryer
Kenmore gas dryer no heat . 90 series model 110.70902990 have power, did vacum lint from access panel@ FRONT
unplug the dryer,remove the lint filter,take off the bottom panel and remove the duct that the lint filter slides into,clean the duct out,while you have the duct off on top and to the right of the blower wheel housing you'll see a 3390719 thermal fuse,remove one of the wires and check it with your meter to see if it's good,most of the time if the dryer hasn't been cleaned out the fuse will blow,the dryer runs to hot and the fuse is a safety so you don't have a fire and so the dryer doesn't run hotter than it should. vac out the inside of dryer and if you have a shop vac it blows on the other side,blow off the motor and blow the lint from the back forwards so you don't have to remove the drum,next you have to clean out the vent line,if it's a long run from the back of dryer to the outside flapper i use a leaf blower to blow out the line,you should clean the dryer once a year,if the fuse is good you need to check with your meter the ignitor,the sensor and the gas coils to see what's bad,if you need anymore help let me know,good luck,when you're reading anything out with the meter make sure you remove at least one of the wires or you'll get a false reading
Mar 16, 2010 | Kenmore Dryers
Hello. Love this site! My dryer is not heating
unplug the dryer,remove the lint filter,take off the bottom panel,now remove the duct that the filter slides into,the thermal fuse is on top of the blower wheel housing or on the top right hand side from where the duct was attached too.pull one of the wires off and check it with a meter,and while you have the duct off,clean it out,also vac out the inside of dryer,if you have a shop vac put it on blow and blow all the lint from the back to the front so you don't have to pull the drum to clean it,blow off the motor,now clean out the vent line and clean out the outside vent,i use a leaf blower to blow out the vent line if it's a long run,if it's not to long use the shop vac to blow out the line,you should do this once a year so you don't have a fire and you won't pop the fuse and your clothes will dry on time,good luck
Mar 15, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kenmore laundry station, that has a washer on the bottom and a dryer on the top. I replaced the thermal disks, the dryer heated for about 24 hours, then it stopped heating again. Do I need to...
do you mean the thermal fuse?if it popped again it's probably overheating,you need to clean out the vent line and the duct that the lint filter slides into or it will keep doing this,if the vent line is long you can blow it out with a leaf blower,make sure nothing is blocking the outside vent,the fuse is a safety switch that pops when the dryer runs to hot,gotta clean out that dryer once a year
Feb 24, 2010 | Kenmore Dryers
Kenmore 110.72942100 gas dryer. slow to dry. heats a couple of seconds then off a minute or 2 then heats a couple seconds again etc. you can hear the gas valve go off & on. I'm checking this with the...
check outside to see if the air is blowing out with force,if the vent line is blocked with lint,also take off the bottom panel,remove the lint filter and take off the metal duct that the filter slides into,clean that out and vac out the inside of the dryer,if you have a shop vac the other side of it blows,blow off the motor and blow all the lint from the back to the front so you won't have to pull the drum to clean it,you should do this at least once a year more so with gas because you have an open flame in there and you don't want a fire,if the vent line is a long run i use a leaf blower to blow out all the lint out of the line,this is a common problem,next you'll start popping the thermal fuse or high limit thermostat
Jan 23, 2010 | Kenmore 74602 Gas Dryer
Kenmore Elite Sensor Smart Gas Dryer - no hot air
unplug the dryer,if you haven't cleaned out the dryer check the thermal fuse located on top of the blower wheel housing,remove bottom panel,then remove lint filter,now remove the duct that the lint filter slides down into,now you'll be able to check the thermal fuse located on the top right side of the blower wheel housing,there's also a thermister there too,the fuse is the one on the left,part number 3392519 or 3390719,remove one of the wires and read it out with your meter.also while your in there vac out the inside of dryer,if you have a shop vac put it on blow and blow off all the lint that's built up on the motor and you can also blow the lint that's in the back of dryer forwards so you won't have to pull the drum,if you have a long run on the vent line from the wall to the outside blow it out with a leaf blower,if there is any blocks in the vent line,the duct or lint inside the dryer you could have a fire so this should be done every year,now if the fuse is good you gonna have to read out the ignitor,the sensor and the gas coils,if you have parcial heat it's definetly the gas coils,when they heat up they stop working when they're bad,if you need anything else let me know,so check the thermal fuse first,then the ignitor,sensor and coils,if they are good check to see if power is coming down to fuse and ignitor,you have a computer board on this dryer but most of the time it's the fuse and a dryer clean out
Dec 16, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 110-66652501 runs but does not
did you clean out the duct that the lint filter slides into?you still have a block somewhere and sounds like you popped the thermal fuse part 3392519,unplug dryer take off vent line and remove the back panel,take out the 2screws on top of dryer and remove lint filter,on left side remove the 4 screws and remove the duct,clean it out,to the right of it and around 4 inches up from floor you'll see the white thermal fuse,read it out with a meter,also if you have a long vent line from the wall to the outside blow it out with a leaf blower and make sure the outside flapper is blowing fully open
Dec 13, 2009 | Kenmore 63942 Dryer
I put in a new heat element and a new theromsat
you'll need a meter to read out your parts,if you read out the heater you would of known it was good and wouldn't of had to change it,check the thermal fuse located on the blower wheel housing,if your lint filter is inside the fuse is in the front,if it's on top the fuse is in the back,also if it is the thermal fuse you probably need a clean out,clean the duct out where the lint filter slides into,vac out the inside of the dryer and clean out the vent line if it's a long run blow it out with a leaf blower,makw sure the outside flapper is blowing fully open you should clean out the dryer like this every year so you don't have a fire
Dec 10, 2009 | Kenmore 800 6983 Electric Dryer
Drum rotates. No Heat. Kenmore Electric Dryer
check the thermal fuse on the top of blower wheel housing,also while your there take off the cover of the housing and clean all the lint out,if your fuse was popped the lint buildup did it,check outside and make sure the air from dryer is blowing out and is not blocked,if it is blow out vent line if it's a long run with a leaf blower,if the thermal fuse is good read out the heater with a meter and if that's good read out the t-stats
Nov 15, 2009 | Kenmore Dryers
Dryers Logo
126 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
