My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
  • 4 more comments
  • sboyd184 Jan 13, 2009
    That thought had crossed my mind. I don't suppose you could offer any underpinning knowledge to add to your response?? Thanks.
  • dave4447 Jan 24, 2009
    On Power up the error code E9 displays with a continuous beep,
    Same problem. Anyone know what E9 means?
  • sboyd184 Jan 30, 2009
    Thanks Dave, I appreciate that. Mine seems to working OK now. At least I know where to start looking if it plays up again.
  • Devon
    Devon Dec 22, 2013
    I replaced the sensor, didn't fix the prob. Eventually found a broken contact in the plug that connects the sensor to the circuit.Inserted a sliver of thin copper , 1.5mmX15mm, bent into a tight u-shape.Paid $70 for a sensor I don't need...
  • Anonymous Mar 29, 2014
    on power up the error code E9 comes up and prevents the machine from filling.
  • Brett Anderson
    Brett Anderson Jan 20, 2018
    Where is the water sensor located
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Posted on Jan 27, 2009
  • Holly Macnamara
    Holly Macnamara Apr 25, 2014
    Where abouts is the water level sensor located on the machine?
Buy a new one
Posted on Jan 13, 2009
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Apr 25, 2014 | Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
I have a nec nw-652 top loader when i start the machine the water fills the tub but at the same time i can hear small amount of water is going down the drain then stops. Once the water in machine is topped...
Hi just read your posting.Now can you please let me know where your drain hose is draining to,Is it into the laundry sink or some place else.Can you see the water coming out of the drain hose?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Sep 18, 2010 | Washing Machines
I also have an NEC NW-452 Washing Machine,it has stopped working completely,doesn't power-up at all,the User Manual troubleshooting guide is no help at all,I tested it it with a Digital Multimeter to see...
take the top off and follow the mains cable to where the cable is connected in the terminal block it could have come loose or the cable itself is at fault check the wire from the plug terminals to the terminal block eric
Dec 27, 2017 | Washing Machines
NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Aug 01, 2009 | Washing Machines
The NW - 891 NEC washing machine does not finish the third cycle or drain?
Our nec washing machine nw 891 leaks water into drum when finished , I think it needs new washers, is this hard to do?
Aug 06, 2008 | Washing Machines
NEC washing machine displays E9
fault code e9 relates to pressure sensor.
Apr 29, 2008 | Washing Machines
Washing machine nec nw-652
i am having the almost the same problem with what i have, if it is turn, the water will just keeping on pouring in non stop, it does matter wether it is wash, rinse, dry or spin the water will just keep on pouring in at all time, it is not a good machine at all.
Sep 09, 2007 | Washing Machines
Washing Machines Logo
1,135 people viewed this question
Top Washing Machines Experts
