Myy tv screen is not working
Stand by light flashes orange. can hear sound but not see anything on the screen
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Since there are a lot of different types of projection sets let me know brand and model number first.
Posted on Dec 10, 2012
  • matthew Dec 11, 2012
    toshiba regza. model number 37RV753
  • SD Tech
    SD Tech Dec 11, 2012
    I have seen the reviews of this model, basic and bottom of the line unit==to your problem==this model is reported to have some issues with the backlight that provides the light for the picture on screen, something simple you can try to verify this, Get set in a very very dark room and turn on, with a flashlight point at a angle across the screen, you are looking to set if a very faint image can be seen, be patient as it if there will not be overly bright. If you see this image the backlights are either not being turned on by the set, minus the voltage to power them or BAD.
SOURCE: orange/amber light
the orange lamp is suposed to be on when the set is off but there is still power to the set
red will be on when in standby
green when set is on and working
Posted on Apr 12, 2009
SOURCE: TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
i have a toshiba dlp doing that after research i found it to need a lamp replacement
Posted on Apr 20, 2009
  • 126 Answers
SOURCE: tv is running then screen turns red and then stand by light flash
The red picture tube has an internal short. Hitch is that the tube is no longer availible. But the tube can be rebuilt. A tv shop can pull the tube assembly and ship it off. This is a very reliable repair but expensive. Average cost is between $400 and $500.
Posted on Jul 10, 2009
  • 55 Answers
SOURCE: standby light flashing
check the owner's manual, you'll see what the indicator light code means. More than likely it's your tv lamp.
Posted on Apr 21, 2010
SOURCE: changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Posted on Jan 21, 2011
My Samsung TV won't turn on
Please describe the problem more accurately. Flashing red usually means 'stand-by' state, flashing blue/green - starting up. When (during that) do you have a sound? Are there any 'high voltage' sounds like soft screeching from the screen? Is it LCD or LED?
Mar 02, 2015 | Samsung Televison & Video
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
having problem with sony television the screen when its turn on no images found just found red color on the screen..
Feb 01, 2009 | Panasonic TX-42PT10 42" TV
Changed bulb, now tv does nothing. . .please help
Mar 07, 2008 | Televison & Video
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Sony 35inch Trinitron Color TV
Try hooking up a vcr or dvd player that you know works.The TV "thinks" it's not getting a signal. Be sure the TV's on ch #3 or #4, depending on the output channel for the vcr. If you see/hear the tape on TV you know the TV's ok and the problem's in reception, maybe a loose connection.
Dec 17, 2007 | Sony KV-35S40 TV
No image, Hear sound, Flashing light
Look for over-heated area on PCB===change 47mf/25v cap and two xistors== BC-327-25=BC-328 BC-337-25=BC-338 This solution is offered for L04-01 chassis.
Oct 01, 2007 | Philips 27PT6442 TV
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
