Question about Refrigerators
Indesit intergrated fridge gse160 not cooling
2 Suggested Answers
  • 54 Answers
SOURCE: Indiset Fridge not cooling
If the compressor is running and not cooling then there is no refrigerant circulating in the refrigerator or no air moving across the one or both coils. No ice in the freezer section indicates that no cooling is taking place at all, pointing to a lack of refrigerant rather than poor air circulation due to a bad fan or frozen coil.
You can try a manual defrost to ensure it's not a frozen coil by unplugging the unit for several hours with doors open then starting it again. If there is still no cooling occurring you need to check the refrigerant level. If its low you will have to find and seal the leak, pressure test with nitrogen, evacuate and weigh in the correct amount and type of refrigerant listed on the unit.
Hope this helps, needless to say be sure to find a reputable qualified technician to open and service your refrigerant circuit this will make or break your unit.
Posted on Mar 15, 2008
Connecting a indesit iwdc6125
you can fit it you have to trim the continuous plinth either side of cabinet . also check your new washer will fit under the worktop freestanding appliances are 85cm high integrated are 82cm.
Jul 16, 2010 | Washing Machines
CONDENSATION ON BOTTOM SALAD CRISPER SHELF OF A WHIRLPOOL INTERGRATED FRIDGE
cold,damp air,condensates on warm shiny surfaces(bathroom mirror),try putting kitchen towel under the crisper...(why they put crispers on bottom of fridge instead of on top of the cooling coils at the top of the fridge ???)
Mar 29, 2010 | Refrigerators
Since defrosting my freezer my fridge does not appear to be working correctly. The thermostat is turned up full however the fridge is not cooling. The seal round the door is fine and there is no blockage...
So you manually defrosted your refrigerator and now the fresh food section is warmer than normal. Can you please send me the model number and your location in the world. Some models are totally impossible. I found related models but no parts listings yet. Could you have someone feel the compressor top to see if warm, cool or too hot to keep hand there. Sea Breeze
Mar 18, 2010 | Refrigerators
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Indesit fridge freezer.
lower the number, warmer the fridge.
setting 1 - warmest
setting 5 - coldest
this is the same for all fridges
Jun 29, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
My fridge/freezer is an Indesit and the fridge is not working and the freezer has defrosted. The light still works inside so l know there is power. The pump at the back is warm to touch. Any ideas whats...
Greetings suepentony.
Generally when your fridge stops cooling and your freezer also is having diminished function, it is an indication either your compressor is going bad, or you need freon. I would suggest having a repair person come check out the unit as soon as possible to prevent further food loss.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 18, 2008 | Refrigerators
Mar 11, 2008 | Refrigerators
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
