Question about Dell Office Equipment & Supplies
Dell printer v313 reports paper jam but no paper
    New Friend:
  • 10 Answers
Turn it off for a few minutes - open everything that may be opened to remove paper jam - check for a bit of paper under print head. turn it back on and see if it reboots without the message
Posted on Dec 10, 2012
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
SOURCE: Papr Jams and wrong size report
We just solved this problem with our c900.
Basically, a paper jam has caused some probs with the sensors and rollers. After playing with the thing for about 4 hours, i ran some really thick photo paper through it and after a couple of trys where it just screwed up in the back, it then fed through and printed correctly. After that it was fine with all paper types, no more messages, and no more paper getting screwed up in the back. Ian
Posted on Jun 19, 2009
devdeep545
  • 137 Answers
SOURCE: Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Posted on Aug 09, 2009
Peoples book
  • 9 Answers
SOURCE: Paper jammed (Dell lase Printer 1720dn
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Posted on Aug 22, 2009
SOURCE: Dell 3010cn paper jam 075-134 cannot get rid of error
The reason Dell said this problem was almost impossible to fix is because it is. There is a lift mechanism inside the housing for the MPF paper tray that lifts the paper to the roller to pull off the top sheet. The lift mechanism in this printer model is flimsy at best. There is a roller cam with a knuckle attached to it to does eventually break, causing a failure of the lift mechanism. The components to repair this problem are unavailable from Dell, and can only be salvaged from another printer. Here's the kicker... You have to disassemble the ENTIRE printer in order to replace this assembly. This took me 2 and a half hours to accomplish, and you're going to have to do it on 2 printers, as well as reassemble the fixed one. DO grease the cam assembly with some white grease to get the longest life possible if you choose this option. Best option? Either purchase another printer off eBay with a different problem and use yours to fix that one, or, as Dell so lovingly suggested, purchase a new one. The cost of today's color laser solutions make purchasing one of these printers a much more viable option than fixing your 3010cn.
Posted on Aug 31, 2009
I just install a new v313 printer and the printer says that there is an obstruction with the printerhead. It makes a loud cracking noise. I have taken the ink cartridge out with its base and it then its...
Sounds as if there is a small bit of paper jamming it. Also, if it is just out of the box, make sure you haven't missed any of the packaging tape that is used to secure everything.
Mar 19, 2011 | Dell V313w AllInOne InkJet Printer
Everytime i try to print or copy it keeps saying paper jam and theres no jam i can see i put just one piece of paper and its not running through
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $59 with warranty..
Dec 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
Menu states that i have a carrier jam but there's no jam
Dec 23, 2009 | Dell 924 All-in-One InkJet Printer
I have a dell Photo 964. I shut off the printer to clear a paper jam and it went dead. The on/off button light does not even light up.
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $119 with warranty..
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
Ink cartridge jam will not kick back to center
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality with warranty for $59.
Dec 20, 2009 | Dell 926 All-In-One InkJet Printer
How can i fix a paper jam
The simple answer is to tell you to remove the paper jam. Make sure you get the entire page out of the printer.
There are two types paper jams.
1) An actual paper jam.
2) If paper does not reach any of the paper path sensors in the time allotted to reach it, the sensor reports a jam because something prevented the paper from reaching the sensor.
A quick test would be to place some marks on the top sheet of paper then initiate a feed cycle. If the paper stays in the tray, then you have a paper pick problem and more than likely you will need to have the printer serviced.
Don
Dec 14, 2009 | Dell 924 All-in-One InkJet Printer
PRINTER JAM
look for small, small pice off papper in the printer where pappers pass tru
Sep 29, 2008 | Dell 1720dn Laser Printer
Curled corner causing a paper jam
Try replacing all paper. Sometimes paper that is overly humid or has gotten wet will curl. Replace with new paper and report results.
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
66 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
