SOURCE: Toshiba 57H81 57in. Rear Projection Please help us get started
this set has a scan converter board that causes this prob. it can be replaced or rebuilt. rebuilt is the best option. by tv tech..john
SOURCE: scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have had this problem in the past with Comcast. You need to go into the Power off menu (hit menu with the power off on the cable box) change the resolution to 1080I. Good luck.
SOURCE: toshiba tv model 42h83
DID SOMEONE EVER FIND A SOLUTION TO THIS PROBLEM? CAUSE I HAVE THE SAME ONE
I have a 53inch philips that is showing pictre but showing green, red as shadows..
SOURCE: I get a color picture when i hook up the
What color jacks are you connecting your box to. Sounds like you are connecting 3 wire video or component connection incorrectly. Green,Blue,Red wires require same on both ends. If not correctly connected you will get the picture you are describing. The yellow wire composite video requires only one wire. I see this all the time . Some one has connected the yellow wire out the the green component in.The componet video takes 3 wires for video and 2 for sound five all together. the composite video yellow wire takes 1 video and 2 audio wires. Can't mix them together they are different. Hope this helps you.
