Question about Apple AirPort Extreme Base Station 802.11g/b Wireless Access Point
Apple extreme bridged to apple extreme (Windows network)
Upstairs:
2Wire 3800HGV-B Gateway>>cat5>>apple extreme
Downstairs:
apple extreme>>cat5>>switch>>laptop/xbox/wii/ps3
How do/can I connect upstairs to downstairs wirelessly with internet for all ?
    Problem Solver:
  • 5 Answers
Using a wired connection:Using the Airport Utility, set up the extreme wireless with the same network name, security and password as the 2Wire but use a different channel. On the Internet Tab, change Share a Public IP address to OFF Bridge Mode. Click on Update Button.
Using a wireless connection: You will need 2 Apple devices, at least 1 Extreme and the second can be either an Extreme or Express. Replace the 2Wire with the extreme and using Airport Utility, set to "Allow this Network to be Extended". Set the second to "Extend a wireless network".
Posted on Dec 24, 2009
  • 34 Answers
I assume you have a Mac - which will have Airport Utility in Applications/Utilities.
The idea is that the Airport nearest the internet wall connection is the 'base' and the other one is the satellite or 'repeater' - essentially boosting and sending the signal to those devices on that floor.
Use Airport Utility to set the satellite base station (the one not connected to the gateway) (go into manual set up and select the Wireless button). In the first drop down, select 'Participate in a WDS network'. Then update to restart the Airport.
If you are unfamiliar with using Airport Utility, then I'll post step by step instructions. Good luck!
Posted on Aug 11, 2009
  • 45 Answers
Use the Airport configuration utility. Setup your main base station (the one connected to the 2Wire modem). Then go configure the downstairs one using the same Apple Airport Utility. Bridging should be an option, but is not available on all Extremes. Bridging isn't listed as bridging per se, but as "I want to extend my network" IIRC.
Posted on May 02, 2009
    Novelist:
  • 89 Answers
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Posted on Apr 01, 2009
I have a 2wire and a wireless router Belkin34e. I cannot get the preception I need to watch my movienite streaming media player. I have a tv upstairs and downstairs and the preception is poor for bothl.
The best is to use an Ethernet cable.But if you cant wire up you will need that one of your device be downstairs.In order to do it you need to configure one of them as an access point bridging one router to the other.Or get a Wireless Extender that is a hardware devices that act as either bridges, allowing you to connect a wired device to a Wi-Fi network without need for additional cabling or networking configuring, or they act as repeaters, extending a wireless signal beyond the normal bounds of range.
Apr 11, 2013 | Belkin Components Belkin N450 DB Wireless...
I bought second hand 2wire 3800hgv-b and looking for 2wire Generic Firmware or this version 5.29.135.47 so the gateway could be use with different provider.
Hi i dont think you need to change the firmware for the 2wire to support a different provider. all you need to do is to change the activation keys
Check this link : http://support.2wire.com/index.php?page=view&article=789
Dec 31, 2010 | 2wire 2700HG-B Router (2700HGB)
2-Wire 3800HGV-B bridge mode
Hello my friend,
You can disable all routing functions for your Home Portal. I never advise this as a course of action as it typically causes more issues than it resolves - so procede at your own risk.
- use the button on the back to reset to factory state (hold for 30 seconds)
- browse to gateway.2wire.net/mdc
- click on configure under broadband link
- set ATM PVC search to disabled
- set connection type to direct IP
- click on configure services under the advanced heading
- take note of the text under "If you want to connect to the gateway when it is in bridged mode"
- un-check the enable routing box
- submit your settings
Good Luck!
Oct 30, 2009 | 2wire HomePortal® 1800HW Router...
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have my epson stylus dx6050 upstairs in my house,and I have my laptop downstairs.I want to use the printer without having to connect to it upstairs.Wirelessly ?
Apple Airport wireless router allows a printer to be networked by plugging it into the router. The Airport will work with Windows PCs.
Jul 23, 2009 | Office Equipment & Supplies
2Wire 1800HG network disconnecting.
it may be tha one is acting as a server, When he turns his on or off you are losing the connection, try hooking them up in a different configuration, or leave his on when you are online instead of turning it off and on
Mar 27, 2009 | 2wire 1800HG Router (RG1800HG00)
3800HGV-B and LinkSys Dual-Band Wireless-N USB Network Adapter
Because the linksys is talking about SecureEasySetup which most lynksys routers use. The 2wire 3800HGV-B button is not a SecureEasySetup button.
Mar 18, 2009 | 2wire (1000-400108-001) Router
Problem connecting to my network
What I would do is replace the wireless router with a 4 or 5 port switch to control computers (devices) downstairs. Or, if you need wireless access, purchase only an access point to cover downstairs.
This way the wire from upstairs goes directly into the access point and you have wireless access downstairs.
And yet another way would be to purchase Airlink 101 PowerEthernet boxes ($54.99 each) and use those to connect an access point anywhere in your home that has an outlet.
Nov 19, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
My usb adapter (2wire 802.11g usb wireless adpter) is having problems.
you cant change the wep key on the upstairs pc unless you change it on the 2wire 1st. the pc wep key has to match whatever the 2wire has it set to. go to the 2wire router settings throught the downstairs pc that is working to be able to see what the wep key is set to, then when you get the key or set a new one enter that key into the upstairs pc.
Jan 08, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Apple AirPort Extreme Base Station 802.11g/b Wireless Access Point Logo
900 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
