Question about Toshiba 46HX83 46 in. Rear Projection HDTV-Ready Television
Toshiba 46H84 with vertical bars, how do I fix this?
Doesnt matter which input I use. It doesnt get better over time. I have sound. I tried the auto convergence but that didnt clear the problem. I am computer tech, but clue how to fix this. Is there a kit available to fix this? Can this be fixed in service mode?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If you are getting noise lines left to right etc do some research to see if this set has a Hyper board which has about 12 surface mounted caps inside that can cause this issue, not real easy to replace and COMMON on a lot of the Toshiba sets.
Posted on Dec 10, 2012
Testimonial: "Thx for the response."
  • Tony
    Tony Dec 10, 2012
    It does have a hypermodule part number MHSU11. To be clear the lines are white about an inch apart across the screen, kind of like jail bars but wavy.
  • SD Tech
    SD Tech Dec 10, 2012
    yes, In our shop we long ago gave up trying to fix those as too time consuming---you may want to look around as I did (can't find it) as there was a service bulletin for one of these Hyper boards with a photo of the board---all the caps that failed were circled in the photo--its from Toshiba.
  • 65 Answers
SOURCE: Toshiba 55H70 had convergence problem fixed that now vol.went out
check to make sure that the tv switch on the back panel for surround sound is not in the on position check the customer menu to make sure that the speakers are turned on
Posted on Dec 09, 2006
djnick989
  • 1067 Answers
SOURCE: Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Posted on Jan 29, 2008
welcomejee
  • 10594 Answers
SOURCE: looking for a service manual for a 57h82
I have Toshiba 50H81 manual and can email you, if you need that.
Posted on Apr 12, 2009
  • 53 Answers
SOURCE: Red vertical convergence out. Where can I find DIY repair info for this older set? I found the part online. Is it a solder job or a board replacement?
yes it a soldering job, replace the 2 ics, model no. tsk..., and check the resistors at the pins.
Posted on Apr 20, 2009
blubanshee
  • 48 Answers
SOURCE: Can anyone tell me approx. how much it is to fix a
Hello, If you were able to do the job yourself the part runs around $80 to $100 but this would require you to understand how to solder. I would say if you this is the case it would be worth fixing. If you took the tv to a repair man it would run you somewhere around $400 to $600 to have it repaired. Im sure you know how much these cost and know that you could buy a better tv for that kind of money. I hope my information was helpful and if it was please dont forget to rate my answer. I hope you have a great weekend. :>)
Posted on Jun 12, 2009
Vertical red lines no matter what input.
I'm assuming you're dealing with an LCD flat panel monitor.
If you've tried different input and from different computers and different cables, and you're still seeing vertical red lines, it's highly likely that the LCD is failing and there's not much that can be done easily to fix it. You will probably need to replace the LCD panel.
If the red lines are in different locations each time you power on, then it could be a controller board issue. But, if the lines are always in the same place, it's probably the LCD panel itself.
Oct 22, 2016 | Computers & Internet
Vertical lines when I turn on my Toshiba 51HX84
Thats a common issue caused by bad capacitors on the hyper module
Feb 10, 2013 | Toshiba 46H84 46" Rear Projection...
I have a Toshiba projection tv (46H84). When I
Yes!!!
You need to open the case, then remove the board from the unit, then check all the circuit, probably there's damaged circuit connections, use soldering iron to fix this problem....
Oct 18, 2009 | Televison & Video
I have vertical lines on my screen. They appear to
This a common problem in many of the Toshiba sets----set has a "HYPER" circuit board that processes all the signal for the set--surface mounted caps all start to dry out--always starts out where it will have the problem and then when on for a while it gets better and goes away--eventually when enough of the caps are gone--it never gets better.
Board is now only available by removing it and sending it out for rebuild/repair---company doining this is Pts electronics--part number is:
23148103Cost is about 180 dollars plus shipping and this may mean considering the labor to get the board out that the set is not worth repairing.
Sorry to give you bad news but I am certain this is what your trouble is.
I do this here for free so if this information helped you to decide what to do--take a minute and give me a vote here.
If you have questions or need advice reply to this posting here.
SD TECH
Sep 15, 2009 | Toshiba 46H84 46" Rear Projection...
Toshiba tube tv display doesnt show
when you unplugged it,it reset the clock.you need to set the clock.
on the remote play with the input,menu and display buttons until settings come up.one the date and time is set,probably ok.the best thing is to see if your friend has the manual.there are literally hundreds of different toshiba t.v. alone
May 22, 2009 | Toshiba Televison & Video
HD stations have no picture, sound only. Other inputs show picture.
or antenna try ch 5 ch 12 re auto scan the chs in menu again readjust antenna
Jan 29, 2008 | Toshiba 46H84 46" Rear Projection...
Vertical lines
Oct 31, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba 46HX83 46 in. Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
