Question about Hawking HWREN2 Hi-Gain Wireless-300N Range Extender Pro
Hawking HWREN2 Hi-Gain Wireless-300N Range Extender Pro configuration
At the last step of the configuration setup, the router freezes and communication stop, doesn't matter if you try to config wired or wireless, at the end, doesn't work.
4 Suggested Answers
SOURCE: hawking extender hangs
They just issued new firmware: http://www.hawkingtech.com/support/details.php?CatID=32&FamID=105&ProdID=394#Firmware
You might try that...
-Tom-
Posted on Dec 31, 2008
Ezrahite
  • 2632 Answers
SOURCE: HI I Have a Hawking
Welcome to Fixya. Have you tried to power cycle the router to refresh the ipaddress and can you please make sure that you're trying to connect to your Network Name, If it requires you with a password make sure you type the right password or Network Key. Network Key is case sensitive. You can obtain the information when you access the router.
If you have questions please let me know. Thanks for using Fixya
Posted on Apr 28, 2011
  • 113 Answers
SOURCE: My Hawking 801 is 2 years old. It has started
First thing you need to do is setup the IP, Subnet Mask, and Gateway of
your extender. Before any connection of the extender, we have to find out the IP of the router. Start Menu Run Type "cmd", hit enter In the black command prompt window, type "ipconfig" The ###.###.###.### to the right of default gateway is the IP of your router.
For example...192.168.1.1
Now you can either connect the extender directly to your computer or
to the router.
Use the wizard to find the extender and to change the information of your
extender to...
For example based upon the above #...
IP: 192.168.1.*** (Subnet: 255.255.255.0
Gateway: 192.168.1.1 ( The *** can be any # up to 250 except for the routers...typically we use 235.
After the wizard saves and reboots the print server, connect it back to the
router or leave it there.
Then open up your Internet Explorer and in the address bar, put in the
Address of the router in (192.168.1.235).
It should come up and ask your for the username/password (admin/1234) if it
doesn't then power cycle the device.
On the main page of the extender, fill in exactly the wireless
settings of your router here.
Make sure you fill in...
SSID Channel
Encryption
After you save, you should be able to disconnect the extender via lan cable
from the router and use it wirelessly.
link is here
Posted on Oct 09, 2011
How do i install my belkin range extender?
restart the belkin range extender . and reset the settings i hope this works
Feb 03, 2015 | Belkin Components Belkin - Dual-band...
Hawking Hi-Gain Wireless 300N Range Extender Pro installation
How far did you get when you followed the user's manual?
What stumped you?
Sep 02, 2014 | Computers & Internet
Hawking smart repeater pro
I CAN FIX THIS WITH A REMOTE CONNECTION...call 225-290-5733
Dec 26, 2013 | Hawking Hi-Gain Wireless-300N Smart...
Hwern1 hi gain wireless 300n range extender
what issue are you facing? its not connecting to your existing wifi network ? let me know if you want me to call you if u r in US
Dec 06, 2013 | Hawking HWREN1 Hi-Gain Wireless-300N Range...
Belkin n300db range extender setup problems
we will give you full guidance how to install Netgear N300 wireless.
There are following steps
Step1: Unplug the power to turn off your modem
Step2: Connect one end of the yellow Ethernet cable to your modem and the other end to the internet port on your router.
Step3: Plugin, then turn on your modem
Wait approximately 2 minutes, if your modem has a battery backup, first remove and reinsert the battery before connecting your modem to power.
Step 4: Connect the power adapter to the router, then plug it into an outlet. Wait until the wireless LED turns solid green.
Step5: Connect the router to your computer
To know more information
How To Setup Belkin Range Extender TechVaidya
Sep 07, 2012 | Belkin N Wireless Modem-Router F5D8633au4A
My Hawking 801 is 2 years old. It has started losing its configuration. I launch the set up CD, follow the instructions, put it within range of the main wireless router and in less than 30 minutes it...
to the router.
extender to...
SSID Channel
Encryption
link is here
Oct 09, 2011 | Hawking 802.11g Wireless-G Range Extender
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
Sep 24, 2011 | Hawking Hawkin HiGain HWREN1 Wireless300N...
Hawking wireless 300n Won't Reconnect if Router
try turning on an open NAT configuration, opening your ports on the router, look for tutoriales on how to do so.
this will probably solve your problem
Mar 03, 2010 | Computers & Internet
Setup range extender
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
Hawking HWREN2 Hi-Gain Wireless-300N Range Extender Pro Logo
184 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
