Question about Funai Televison & Video
TWO VCRs stopped working.
Both my Funai VCRs stopped working. they'll play for 5-8 seconds then go to standby. Power up results in tape eject and standby. I've cleaned mode switch. Any other suggestions?
    Top Expert:
  • Funai Master
  • 14,553 Answers
Yes, try to look inside (not in play) when you hit fast forward or rewind--are the reels turning too slow or jerking etc?
It indicates a problem with the transport part of the unit---bad drive idler or even a slipping or bad belt or belts if used.
Posted on Dec 11, 2012
  •  Simon Tomsett
    Simon Tomsett Dec 11, 2012
    Transport seems OK. take up works as well as winding.
3 Suggested Answers
jmgldsmth
  • 2005 Answers
SOURCE: Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
Posted on May 21, 2009
Grubhead
  • 5484 Answers
SOURCE: vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
Posted on Sep 11, 2009
How to eject a VHS tape from a FUNAI DV220FX4?
turn off power unplug wait a few plug back in turn on should eject if not try again
Aug 17, 2014 | Televison & Video
VCR Stops on me
Hello Ro Power,
This might be due to the tape sensor malfunctioning. You will need a schematic, and multimeter, and a LED power meter to work on this problem. When the tape loads it causes an LED sensor to become blocked and then the sensor tells the control chip that a tape is present and the the controll chip allows the tape to continue playing, if the sensor does not work the signal never gets to the control chips and since other events happend and triggered the control chip the control chip looks at this as an error and the stops the tape , some units even eject the tape.
If you do not have a background in electronics, I would suggest that you take the VCR to a qualified shop and have them repair it.
I hope this helps,
Thank You,
Shuttle83
Oct 17, 2007 | Quasar VHQ940 VHS VCR
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
VCR ejects tape when I try to record using the timer facility
Simple. The Cassette's 'Prevent Erasure' tab is missing. Just cover with Scotch tape and reload. Now try recording.
Nov 29, 2008 | Televison & Video
VCR Tape playing problem
The mean time between failure for the rubber parts in a VCR is about the same as the rubber parts on your car - about 5 to 7 years. You are due for a belt job.
Dec 29, 2007 | Televison & Video
VCR tape playing error
It needs its belts replaced
Fault code possibly
this is when the take up reel either stops or when the reel pulses arent been read properly,have you tried a different tape??.It can be caused by tight tape,if this doesnt work is a job for your local sony service center
May 12, 2007 | Sony GV-D800 Digital 8 TM VCR
Televison & Video Logo
77 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
