Question about Olympus Camedia D-40 Zoom Digital Camera
No workie According to son had trama blow on hiking rail. Now only shows, even with door closed"CARD COVER OPEN".
    Genius:
  • 2,985 Answers
Brocken sensor or catch on the cover Check the cover and see that there is a catch that goes into hole- it has probably broken off and therefore not making contact. If so thry a match stick or similar into the hole TThis will [hoepfully put the warning out even if the cover is open. If so leave it at that. If not a repair shop job- but warned big bucks just to look and parts may not be available
Posted on Jun 11, 2007
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
Bottom freezer will not open
If you freezer door was left open for an extended period of time the rails that your bottom freezer slide on are most likely frozen. Repair #1 once you get the door open about every hour go in to you kitchen and open and close the freezer door a couple of times. Repair#2 Take your freezer door off remove the rails take a blow dryer and dry the rails untill you do not see any more water then add a sylcone based greast to the ball bearins on the rails and resinstall. Repair#3 Order a whole new set of rails.
Sep 01, 2011 | Kenmore Refrigerators
Card Cover Open
I have the same problem. The card-cover has to be physically held down for the camera to work. I have even taken pictures and because I didn't hold the card-cover down hard enough the pictures disappeared.
I have noticed on my camera that tiny portion of the plastic card-cover is missing. It is the very tip of the card-cover and would normally be angled up to snap into place and hold the card-cover closed. Apparantly this tiny piece of plastic broke off and now the whole camera has to be carefully handled. Can anyone tell me where I can get another card-cover?
Dec 15, 2009 | Olympus Cameras
Bullets get gamed and lever locks up in open position. Son took it apart to clean side door n wrong place. bullets don't load the way it did Bottom slide to load seams to be in wrong place. load door in...
have a look on the internet there are blow up photos of the marlin rifle there realy very easy to strip, but putting them back right,,,
well your lad did not! *** him!! wip the screw out the side for the under leaver half open the bolt and pull the under leaver down and out the gun, then pull the bolt out the rear end,,you may see what he has *ucked up in there,,,the side loading door is held on be a small screw if you drop the side door into the gun you will need to strip out the loading leaver as well to put it right,,,so dont do that!,,, let the side door screw off just a little and put the door in the right place then nip up the screw,, dont strip it!!! then slide the dolt half way into the rifle and push the loading under leaver back into the bolt,, put the under leaver screw back in and close the bolt with the leaver,,,if its not closing its in wrong again,,,rember you need to engage the leaver in the bolt before you can close the bolt,, if its not picking up the rounds its the lifting arm,,,thats a man size job look on the net for the blow up photos,,,but you may well need some expert help then,,,im not there but if i was i could strip it in my sleep? but go to googel,, and type in "marlin rifles"
Nov 18, 2009 | Weaver Marlin Rifle Picatinny Rail Base...
Track rail bends when closing the door
I think you need to take the cover off the motor unit and watch the limit switch assembly in operation. Takes only a few seconds to see how it works and see if it is damaged in some way. You need to turn the down limit adjustment in the opposite direction of the arrow printed on the cover to stop the door sooner. I think the down force adjustment on the rear of the motor unit is out of adjustment also. This adjustment affects the safety of the opener and should only be adjusted high enough to consistently close the door.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.http://olympusamerica.com/cpg_section/cpg_servicerepair.aspOlympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $124 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 11, 2009 | Olympus FE-190 Digital Camera
Every time i turn on the camera it say card-cover open
clean the seal around the door... else it is repair
olympusamerica.com/repair
Jan 20, 2009 | Olympus FE-310 Digital Camera
My screen keep showing the Card Cover Open Error even though the cover is closed. What can i do It says "Card Over Open" when it is closed
The card door sensor is either damaged, failing or gone completely. You can take camera apart, (7 screws I think) take the back off. Sensor is at the back of camera near the battery door. If sensor is missing, you will see 2 spots on the electronics board where it was connected. Carefully melt solder so that those two points are connected. If sensor is still in place it's probably damaged. Carefully remove sensor using small snips or something like that, with out damaging anything around sensor. Then solder 2 points together. Good Luck
Apr 09, 2008 | Olympus FE-190 Digital Camera
Olympus Camedia D-40 Zoom Digital Camera Logo
95 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
