Question about Toshiba Computers & Internet
When i turn my computer on the it boots but goes to the screen with the blinking white line and doesn't do anything else
  • Toshiba Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Dec 10, 2012
sweetyanne
  • 68 Answers
SOURCE: Cannot start Windows
You can also try to do a repair install using the windows operating system disk, if you really cant login using safe mode.
Posted on Oct 31, 2008
kamal1984
  • 1383 Answers
SOURCE: The computer isn't booting up
first check in biois your harddisk is detected or not.
if not then open cpu cabinet and reconnect all connection to harddisk.
Posted on Jun 11, 2009
  • 30 Answers
SOURCE: MY COMPUTER BOOTS UP BUT
Press F8 as it boot and when u get to the other screen choose LAST KNOWN GOOD CONFIGURATION hope this helps
Posted on Oct 28, 2010
  • 4 Answers
SOURCE: What does it mean when I turn on computer and it
It means your hard drive has failed. you will need to install a new hard drive and reload your operating system.
Posted on May 29, 2011
hunter19_46m
  • 7482 Answers
SOURCE: My hp pavilion a1420n wont boot up. It shows the
Hi...jimmylang13...
Start your computer in the Safe Mode.
To start in Safe Mode
Turn your computer on
Keep tapping F1,F2 or F8 while the computer is starting up
When the computer starts select Safe Mode..(depends on your computer).
1. Uninstall any softwear you may have put on the computer before the problem started.
2. Do a complete System Restore: Start>All Programs>Accessories>System Tools>System Restore.
This will bring your system back to a time before you installed the softwear or Microsoft installed drivers,etc.
Note: Just be sure to use a date in a darkened box before your trouble start date.
When you have done the above, restart the computer and if your still getting the blue screen of death, the installed drivers,softwear,etc might have
corrupted the Operating System.
If that happened then that means either repair or reinstall the operating system.
You will need to do the following:
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select Install if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
If this fails to clear your blue screen of death then you have a hardware problem.
It could be faulty ram
If you still get the BS (Blue Screen), then you have two choices.
1.Reinstall the entire Operating System and you may have to update some drivers.
This will require you to go back to the start of the repair info and select Install instead of Repair.
2..Take your machine in to have the hardware tested.
Keep in mind that if you do a complete reinstall of the Operating System you will lose all the information on the computer,such as pictures, programs, videos, everything you installed will be gone.
Please take time to rate me four thumbs up
Posted on Sep 18, 2011
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
G61-306NR power button doesn't work
Disk Drive works, Memory is good, so any Blinking Lights or Beeps when you hit the power button? Does anything ever post to the lcd screen when you press the power button?
It sounds like either you've got a memory issue or a video card issue. Just because the memory worked in your friend's computer does not mean it will work in yours. Your Slot where the memory goes might be bad.
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 11, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Acer desktop with black screen and line blinking
I'm thinking from what you describe that you are just looking at the cursor blinking in the upper left corner of the screen.
You haven't said what you did or what you are trying to do, but I suggest you turn the computer off (just push the power button in for about 7 seconds) and then restart it after about 15 seconds. If it doesn't start, go through the process again but this time, after you turn it on, tap on the F8 key. Like tap---tap---tap and keep doing that until you get a black screen with a white menu on it. Use your arrow keys to select "repair your computer" that you will see if you are using windows 7.
This should repair you startup problem.
Mar 22, 2012 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
Can't get into safe mode
Have you tried rapidly tapping F8 as soon as you press the power button or did you just press it once? Dont wait for it to get to the blinking cursor page.
Feb 11, 2012 | Fujitsu LifeBook Computers & Internet
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
When i turn on my dell 110 mini the light goes from white to orange and stays there the screen doeset boot or anything
Remove battery, open the access panel on the bottom carefully remove the ram sticks. Put them safely on a piece of paper so that a static charge doesn't ruin them, also touch something metal before you try and remove. If your computer doesn't beep at all when you power it back on your CPU, GPU, or MB are bad. If it beeps then there is still hope.
Jun 10, 2011 | HP Mini 110-1037NR Netbook
I have a horizontal white line has been appearing recently on the bottom of my lap top's screen, i have not installed any new software and it hasn't fell down like ever ... what's the solution...
Just boot to BIOS (either by pressing Del, F2, F10 (depends on the laptop brand).. upon turning on the unit). If the white lines appear, your problem is with the LCD screen.
If no white line in BIOS, install an updated driver of your video card. However, if installing the driver doesn't help, your video card is faulty.
Hope this helps,
May 20, 2011 | Computers & Internet
I am encountering a problem with my eee netbook. When i turn it on , it goes to a blank screen wit a blinking white crusor. Can u please give me step by tep etailed instructions on what to do because i am...
I think what you're describing is a blinking white vertical line, much like you would see in a word processor (or dos/command prompt if you are familiar with those).
If so, the problem may just be a CD/DVD in the optical drive.
If this is not the case boot the computer and enter the bios (the f key can differ, sometimes 'f2' or 'del' key). Make sure that the first boot device is set to the correct hard drive (usually under a 'boot' or 'boot settings' and then 'boot device priority') header in the bios.
If this still does not work, you may need to reformat your computer.
May 11, 2011 | ASUS Eee PC 1000HE Netbook
Emachines T2385 startup problem
Psu is a Power Supply issue but the black screen with a blinking white line is not.
The blinking white line can mean there is no instructions to tell the Computer to boot up. Which could be possibly the system battery (cmos) or Hard Drive.
I would narrow those 3 things down first.
Jun 26, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
