Toshiba DLP rear projection tv noise problem on turn on - model 62HMX85
Lamp blew - replaced it but still get noise on occasion when turning tv on - goes away eventually - sometimes red light changes to flashing green and tv switches itself on and off at beginning
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If its a high pitched or fan like sound (but not a fan) it may be the color wheel going out.
Posted on Dec 10, 2012
  • 192 Answers
SOURCE: HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Posted on Apr 01, 2007
scott201201
  • 170 Answers
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Posted on Apr 10, 2008
techman007
  • 1112 Answers
SOURCE: LG Rear Projection 44" will not turn on
Make sure you reinstall the lamp door as there is a lamp door switch that must be closed or the unit will not fire the lamp, there should be a small hole or opening on lamp door housing. Some people install the lamp without reclosing the door just to see if the unit works , just to find out if it will not work, and when it does;nt think something is wrong, they do not put the lamp door back on first. Not to say this is the case but it does happen.
Posted on Dec 18, 2009
  • 32 Answers
SOURCE: Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Posted on Dec 01, 2010
  • 668 Answers
SOURCE: Hello, I turn on the
The lamp probably has failed. The Part number is ANR65LP1/1
I hope this helps
Skyassoc
Posted on Dec 16, 2010
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at www.TvRepairKits.com and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
When I trun on the tv there is vertical lines. If I unplug the tv it resets and is ok for a will. Now it blew the bulb again third time.
I think you have a issue with your light engine and you need to replace it to be honest with you this part runs from $250dls - $350dls check this link out
Toshiba got a lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 26, 2010 | Toshiba 65HM167 65" Projection Television
On off switch blinking wont turn on
This seems to be common with this unit
the fix may cost between 300 and $400 according to my conversation with Toshiba guys.
here is a trial fix that is only temporary as i believe it will hget steadily worse.
FIX: Unplug and leave for 20 mins, replug and startup as normal.
Hope it helps, Please dont forget to give a rating to our expertise level
thanks Fiya team
Aug 12, 2009 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
