Question about Ignition System for Subaru Justy
CAR STARTS WHEN COLD BUT NOT WARM
WHAT CAUSES THIS PROBLEM
  • 20 Answers
Electrical resistance increases with temperature, If the problem lies with your ignition system then something is likely to be breaking down under load. I would suggest having the exhaust emissions checked when engine is hot to rule out a fuelling problem.
Posted on Dec 10, 2012
I have1990 Chevy Astro van,it starts just fine,when it warms up,driving it or sitting still in drive or reverse, it stalls,I start it back up,in park or neutral,it stays idiling.Idles cold,stalls warm
Check the ECM grounds, they are under the passenger side kick panel. When the engine goes to warm status, the Oxygen sensors come on, If there is no ground on the ECM then it starts pulling ground voltage across the sensors and that causes big issues.
Apr 29, 2017 | Cars & Trucks
Cool mornings it doesn't want to start ,i have to turn the key to start and let it off several times and it will eventually start after that it starts fine all day and starts fine on warm days
How to Start a Car in Freezing Cold Winter Weather
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowFreezing cold weather can take a toll on car batteries. ... It's much more difficult to start a cold car with a mostly-empty tank, so do yourself a favor and gas up ...
Why is it so hard to start a car in the winter? - HowStuffWorks
auto.howstuffworks.com/car-driving-safety/.../start-car-in-winter.htm
To start a car in winter, your engine has to work extra hard. Learn the top 3 reasons your car is hard to start in cold winter weather.
Debunking 5 Cold-Weather Car Myths - Popular Mechanics
Nov 21, 2015 | Cars & Trucks
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
Jul 01, 2015 | AC Cars & Trucks
Will not start when cold
auto shutoff relay controls both fuel pump and ignition..its a little relay that causes a huge headache when it goes bad..causes a no-fire on the car..
Dec 15, 2013 | Cars & Trucks
My wifes 2003 toyota highlander when she starts it there is what appears to be a gas fume like smell in the car. it seems to go away when the engine isd warm
You should have the fuel injectors and the especially the "cold start injector" checked for leaks. The cold start injector only operates during cold starts. If you don't notice the problem during warm starts, then the cold start injector is the place to start.
Feb 08, 2011 | Toyota Highlander Cars & Trucks
Vw cabrilet cuts out when driving
Hi if your car runs fine from cold and starts fine when cold, but then if it starts playing up when it gets to near running normal temp then this is a good indication that the oxygen sensor is up the shoot and will need replacing.
the reason it points towards this being the fault is that the oxygen sensor only starts to work when it reaches a certain temp so if your car runs fine when cold but plays up when hot or warm then the chances are getting the oxygen sensor (or lambda sensor for its proper name) changed should then solve your problem.
let me know how you get on or if you need further assistance ok
May 04, 2010 | Volkswagen Cabriolet Cars & Trucks
Starts cold when warm shuts off
May be the fuel pump, experienced similar problems in 1995 Intrepid. When the pump warmed up, it would start to loose pressure and car would sputter and die, but would start back up. If it started it would usually begin sputtering again and eventually die.
Feb 03, 2010 | 2000 Hyundai Accent
Car hard to start on humid days
Just tuned up a jetta, put di-electric grease under the plug wire boots and especially the coil wire. The moisture causes mis-fire mainly at the coil. His VW had the same problem. Small pack of grease will be enough. buy 2 packs at adavance auto for $1.09 each.
Dec 31, 2009 | 1996 Volkswagen Jetta
Car gets warm and starts hesitating on acceleration
this could be something in the fuel pump. As the cold motor draws more fuel, it may just be just ok for the engine, but after it is warm, it draws less and may "suffocate" it that way. Same goes for air filter, take a peek if it is not ready for replacement. Has this happened suddenly, or has it occurrend during a long perion of time?
Oct 15, 2009 | 1999 Mercury Cougar
My Atlantis Oversize Capacity Washer is the problem.When I select a Warm/Cold wash the water starts out warm, then kicks into hot water. So then I have to hit the Warm/Cold button over and over as it fill...
The temp is controlled by a thermistor to make sure the warm water is warm. If the incoming cold is too cold, or the incoming hot is not hot enough, it will compensate by turning off the cold until the temp comes up, then it should turn the cold back on. Make sure the hot supply is to the hot water valve. If the hoses are backwards it won't work right either. Or you may have a bad solenoid in the water valve. It's possible for a water valve to work when it's cold, but as electricity runs through it, the solenoid heats up and causes it to open electrically which will close it mechanically and turn the water off. Usually if this is the case it won't open again for at least 10 minutes until the solenoid cools down enough.
Jul 21, 2008 | Maytag Washing Machines
Ignition System for Subaru Justy Logo
69 people viewed this question
Top Subaru Vehicle Parts & Accessories Experts
Randy Ohler
Thomas Perkins
Thomas Perkins
Todd Arndt
Todd Arndt
Are you a Subaru Vehicle Part and Accessory Expert? Answer questions, earn points and help others
