Question about Canon EOS 40D Digital Camera
I can not take picture using 100mm micro lense with eos 40d
When i take picture using 100mm micro lense with eos 40d one message appear on my camera sreen
communication between camera and lense is faulty clean the lense contact.due to this message i cant take another picture please suggest solution.
  • Anonymous May 09, 2009
    I have the same problem AND I have cleaned the contacts, tried other lenses and upgraded the firmware etc. What next? I challenge the 'experts' of this forum to provide helpful suggestions.
    I'm really aggravated by the so called 'wiz' on this site suggesting the obvious! If you're a wiz, I expect more than is displayed on my camera screen.
    Otherwise, it seems you post replies just to increase your rating...
  • 115 Answers
??? try to clean the lense contacts!!
Posted on Feb 04, 2009
I have a Canon 100mm macro lens used on a Canon EOS 40D Camera. The problem I have is that the images produced seem to be not pin sharp, even when using a tripod and the mirror lockup function on the...
It seems that you have either a faulty lens or one which is performing outside of the minimum quality standards. You have clearly done everything possible to try and eliminate all other causes. Looking at the firmware updates for your camera, none of them mention an issue involving your lens but you may wish to ensure that you have the latest firmware anyway.
All you can do is to contact Canon customer care to request that the lens is exchanged.
Sep 07, 2010 | Canon 100mm f/2.8 Macro USM EF Lens
I am using Nikon AI lenses on Canon 5D. Results
Having received no response in over a month, I assume this is no longer a problem.
May 01, 2010 | Canon EOS 40D Digital Camera
My Camera is Canon 40D with EFS 17-85mm lense. I am having 2 problems,1.when I zoom the lense at 85 at 'AF' it doesn't get the focus, some times it get focus but picture got blurred.2 after capturing some...
Your flex cable to the Iris is broken. Have a look at my gallery at http://www.pbase.com/barry_2718/efs1785mm I have the same symptoms. At 28 or 35mm it make work ok. try Av mode and f8 aperture to see if you get an err01 because the aperture does not move either.
Jan 02, 2010 | Canon EOS 40D Digital Camera
Lost autofocus on 40D when using ST-E2 and 2 580EX
Try taking the battery out and putting it back in. If that doesn't work try cleaning the len's contact sesnors with a pencil eraser.
Jun 23, 2009 | Canon EOS 40D Digital Camera
Permanent error 06. 17-85 lens damaged when an
It most likely was a short in the repaired lens that caused the sensor to go bad over time.
I have been shooting with Canon cameras and lenses for many years and I do not always turn off power before switching lenses. It is not a big deal.
Jun 06, 2009 | Canon EOS 40D Digital Camera
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
Err99 40d canon body only
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Oct 28, 2008 | Canon EOS 40D Digital SLR Camera Digital...
Canon EOS 40D shoots on its own.
Sounds like a software issue, try to upgrade or reload the firmware.
I hope it helps :)
Oct 26, 2008 | Canon EOS 40D Digital Camera
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Jun 30, 2008 | Canon Cameras
Canon EOS 40D Digital Camera Logo
125 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
