Question about Canon Pixma MX360 Printer
I changed number of rings for fax on canon pixma mx360, now it will not receive fax at all
I changed number of rings from 2 to 5 on my canon pixma mx360. Now it will not receive a fax at all.
  • 76 Answers
SOURCE: Fax with Pixma MP780
if you can hear it connecting and you can here fax tones then it sounds like it going. just place the page in the adf and dial your number and hit send button. how do youknow that the other person is not reciveing it? if you are in the uk then i can send you a page and see what we get?
Posted on Oct 21, 2008
rhoncruz
  • 134 Answers
SOURCE: Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Posted on Dec 01, 2008
SOURCE: canon pixma mx 300 won't send or receive fax
how do u fix the fax to fax and not go on auto redial
Posted on Feb 01, 2009
  • 7 Answers
SOURCE: Cannot receive faxes on Canon Pixma MX870, but can send faxes
I was searching for an answer to this to make sure my new MX870 is correctly set to receive faxes. Here's one answer I came across:
First set Tel-Priority, turn off incoming ring, turn on manual/auto switch, then check how many seconds it takes for your answering machine to come on, and set it a couple of seconds after that. This should do the trick.
Posted on Oct 03, 2010
alpug
  • 1961 Answers
SOURCE: I can't get my new Canon Pixma MX330 to send
Better check the connection at the back of your printer. This is the most common problem encounter when faxing...wrong connection.
1. when using the printer as fax, the line input should be connected properly to the "L" input at the back of the printer
2. The rj11 connector of the phone should be connected at the back of the printer with telephone label in it
I hope that helps.
Posted on Oct 21, 2010
Cannot send receive fax
Make sure the phone line is pluged into the "line" port and not the "ext" or "tel" port. Also try a different jack if possible.
Jan 02, 2014 | Canon Pixma MX360 Printer
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Ip tool reset Canon Pixma MX360 Printer
Apr 15, 2013 | Canon Pixma MX360 Printer
How do I change the time and date on the canon pixma mx360 4in1
How do I change the time and date on the canon pixma mx360 4in1 and how do I put my name on it
Mar 20, 2013 | Canon Pixma MX360 Printer
How can I change it to just print?
First check its cartridges - refilled ones do not work while faxing only if you are willing to print them manually. Printing still works ...
Mar 22, 2012 | Canon Pixma MX360 Printer
I lost my cd to install
download the driver software from
http://mac.softpedia.com/get/Drivers/Canon-PIXMA-MX360-Driver.shtml
Nov 11, 2011 | Canon Pixma MX360 Printer
How do i send a fax?
Hi kimberley299,
To send fax using your Canon Pixma MX340 follow the steps below:
1. First, you need to hook up a phone line from the wall jack to the lower phone jack on the back of the PIXMA.
2. Now go into the menu and set your PIXMA to telephone priority mode (manual fax recieve), fax priority mode (auto fax receive) or distinctive (fax) ring/auto answer mode.
3. To send faxes, put your originals in the feeder or on the glass, select fax mode, enter the phone number, and press start.
Hope this helps.
Thank you for using FixYa.
May 09, 2011 | Canon PIXMA MX340 Wireless Office...
I have new canon pixma mx 328. how to do fax operations of sending and receiving
Hi!
It is very easy
To Send Fax:
1. Place the documents facing down in the flatbed scanner glass or insert in the ADF unit with the documents facing up.
2. Press the Fax button
3. Key in the number of the receiver then press the black or color START button.
4. Listen to the dial tone and see in the lcd display the message "transmitted" to confirm that the documnets have been sent.
Using the phone is attached to your printer (documents is already load to the printer)
1. Call the number of the receiver.
2. Ask for a fax tone.
3. Once you heard the fax tone, press the Black or Color Start button
To Receive Fax (Set up first the number of calls before automatic giving fax tone to caller)
1. When someone is trying to send a fax to you, don't answer the ring on the phone, let the printer give the fax tone.
To receive the fax on the printer with the user's help.
1. When someone is calling, just press the Black or Color Start button.
To receive fax when you answer a phone
1. While the phone is lift up, press the Black or Color Start button to receive the fax.
Hope that information will guide you.
You can thank me by just rating this help.
Thank you for using Fixya.
Dec 14, 2010 | Canon PIXMA MX300 All-in-One Printer
May 13, 2010 | Canon PIXMA MX870 Wireless Office...
Change number of rings before answering
Change the ring count on the fax when the receive mode is set to Fax/Tel or FaxOnly modes. Change the ring count on your answering machine when it is connected to the fax and the receive mode is set [Ans mc connect] (Answering Machine Mode).
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow button to select [Maintenance/settings], then press <OK>.
  4. Press the left or right arrow to select [Device settings], then press <OK>.
  5. Press the up or down arrow to select [FAX settings] (item <1>), then press <OK>.
6. Press the up or down arrow to select [RX settings] (item <3>),
then press <OK>.
7. Press the up or down arrow to select [Incoming ring], then press
<OK>.
8. Press the up or down arrow to select [ON], then press <OK>.
Note: The default setting is [OFF]
    1. A window will appear displaying the number of rings before the machine will answer. Press the up or down arrow to select the number of rings (from 1 to 30 rings).
    2. Press <OK> to set the number of rings.
9. Press the <Stop/Reset> repeatedly to return to Fax standby
mode.
I hope this helps.
Apr 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MX360 Printer Logo
old marine
old marine
