Question about Radio Communications
Top half of freezer on frs-u201a not freezing
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Phillip,
ARE WE talking 2-way radio or fridge/freezers?
If it's the latter, try posting on home appliances forum on this site.
Cheers,
Peter
Posted on Mar 07, 2013
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
Daewoo frs-U2OIC top shelf freezer not freezing
Could be the internal fan at the top of the compartment or its electrical feed is not working. With the door open, hold the light switch in (the fan usually doesn't work when the door is open) and see if it is spinning. If not, it and its connections should be checked
Feb 13, 2012 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
Model FRS-U201A fridge freezer and fridge is not keeping cool, only 3 years old, ssems to have occured in a couple of days
look on back wall of freezer if there is frost build up you have a defrost problem can be defrost heater defrost control board or bi-metal is open and not tuning heater on if no frost you may have low freon problem this can cost check first part of this post 90 % of the time its a defrost issue
Aug 18, 2011 | Daewoo FRSU20IA Freezer
Top half does not freeze
There is a fan behind the back wall of the freezer about 1/2 way up from the bottom, you should be able to hear this running when the freezer is on. If you do not hear this then you need a new evaporator fan motor.
If you hear the fan run then you most likely have a problem with the automatic defrost cycle that would most likely be the heat element that is located just below the coils inside the freezer behind the panel.
Apr 21, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
The top half of the freezer does not work
I have a Scandinova chest freezer and the left hand side froze, but not the right side, because the compressor in the box under the right side of the freezer was getting so hot, a small amount of heat was conducting back through into the right side of the freezer and preventing anything on that side from freezing!
I solved this problem by running the compressor outside of the of the freezer box, by taking the air vent off, unbolting the compressor and then pulling out by about 20cm and running it from there.
Aug 22, 2009 | Freezers
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
My freezer is freezing at the bottom but is not at
Short on refrigerant would be a good starting point, pressure temp relationship should be tested by an opperative.
Jun 27, 2009 | Hoover 9.9 cu. ft. / 280 liter Upright...
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
Mar 26, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Radio Communications Logo
73 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
