Question about KitchenAid KERC500 Electric Kitchen Range
KitchenAid Meat Probe
My meat probe broke off in the temperature probe jack. Any ideas on how to fix this?
Unplug the range and remove the back middle part of the back (should be three screws, I did this yesterday). Remove the rigth side panel by pushing from the back of the range to the front about an inch. It should then be possible to lean the top out and then remove.
Where the probe enters the oven you should see a whole in the side of the oven. If you look carefully you will see the other end of your broken probe sticking out in the open (You may have to move some insulation to see it).
Push the probe back into the oven san you should be back in business.
Replace range side and back (make sure to replace any insulatin which you have moved.
Posted on Apr 05, 2009
Error code f3e3
Swap the leads on the probe jack terminals at the main board
Sep 27, 2014 | KitchenAid KEBS109BSS 30" Single Wall Oven...
My GE double oven displays a message to set probe. When I press probe it prompts me to input a code (3 dashes)? Can you provide via e-mail what numbers can be used to set probe?
It is asking for the temperature that you want the meat to be. Example if you want your meat to have a medium doneness then usually it is 150F. You would enter 150. The probe will beep when the meat has reached that temperature
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Probe indicator beeping. Can't turn off.
there is a continuous beep on my oven and it says enter the probe temperature. I never used and would like to cancel...how?
Oct 09, 2009 | KitchenAid KGST307 Gas Kitchen Range
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Aug 26, 2009 | Dacor Epicure EO230 Stainless Steel Oven
Control panel not accepting commands
sounds as if the meat probe jack is shotring itself. thinks the probe is inserted, adn is lookin to continue on that course. aside form letting it stand and dry out , yo may need to either disconnect or replacethe meat probe jack
Mar 18, 2009 | KitchenAid KERA807P Electric Kitchen Range
Kitchenaid single oven, error code is a picture of a push pin
its a "meat probe" not a pushpin. somehow the unit thinkd you hae a meatprobe inserted, soundslike a short in the meat probe jack( usually happens in high moisture areas, the wires swell and make contact with eachother, the replacement jack, has better insulation around the wires, you could also disconnect the wire harness from the main board assy(behind the console, if you never use the function!
Jan 29, 2009 | KitchenAid KEBC101 Electric Single Oven
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong?
I have the same problem. The problem is the probe went bad. I had a friend with another sumbeam digital probe (the mavrick) put that probe into mine and the temperature reading was working properly. So, now I am looking for a replacement probe. but looks like I will have to just buy another digital meat probe.
Aug 16, 2008 | Sunbeam 4214 Iron
KitchenAid KERC500 Electric Kitchen Range Logo
759 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
