Question about Digix Tablets & eReaders
Digix tablet keeps turning off even when its charged at 85 percent
Like everytme i take it off the charger it just turns off but it can be all the way charged or at leasat 85 percent but when i take the charger out of the device it turns off by itself.
3 Suggested Answers
msoufeer5
  • 170 Answers
SOURCE: my tablet is fully charged
battery shell is weak please replace weak shel
pls vote me
Posted on Jan 22, 2011
KingDWS
  • 1606 Answers
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Posted on Mar 23, 2012
My Irulu 9" tablet I got new. I had it few months is now acting up bad.It only comes on when I plug it up on charger
change the battery
it probably is defective or has developed a memory level for charging when not real low
Oct 01, 2016 | Tablets & eReaders
Is it possible for a tablet's battery to be affected by a faulty breaker in a home if plugged into the direct route of the damaged circuit?
Make sure the charger is providing the correct voltage and current. Batteries that are older and have a lot of charging cycles on them do wear out, so that's a possibility.
Feb 14, 2016 | Samsung Tablets & eReaders
Why won't my Digix TAB-840 will not turn on
There are a couple reasons why your tablet may not be turning on. Has the tablet been fully charged? You may try using a different charger (with the same plug in port type) to see if that helps.
Does it power up but does not load the screen (or gets stuck in boot up)? This could be resolved by reflashing or doing a hard reset. You can get this information from the Contelusa.net website under the SUPPORT tab and DOWNLOADS.
Otherwise you may need to return the tablet to the manufacturer under the 1 year limited manufacturer warranty. As long as the tablet is not physically damaged, you have a receipt from the retailer (or order confirmation), and you purchased from an authorized retailer (they can tell you if it is or not) then you are good to go. Go to contelusa.net and then click on the SUPPORT tab and choose RMA Portal.
Jun 10, 2014 | Digix TAB-840 Android 4.1 OS Tablet PC
Charging battery
The battery may be failing.
Apr 11, 2014 | Toshiba Portege M200-S838 Tablet PC
Tablet's battery lost power and won't recharge
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Mar 07, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
Where do u find cases for a digix 10 in tablet?
I used this case which works perfectly. If youwnat to charge it in the case you can either lift the flep or do what I did and cut a small square where the charge port was with a razpr blade. There is one extra round cutout on the front that isnt on the digix but I don't mind because the case is awsome!
If you check the dimensions of the two tablets you can see they are almost idectical so you get a nice fit.......
http://www.ebay.com/itm/Brown-PU-Leather-Kick-Stand-Case-Cover-F-Viewsonic-ViewPad-10pro-10-Tablet-/330877003512?pt=US_Tablet_eReader_Cases_Covers_Keyboard_Folios&hash=item4d09ce66f8
Jan 08, 2013 | Digix Tablets & eReaders
Tablets & eReaders Logo
121 people viewed this question
Top Digix Tablets & eReaders Experts
matt
matt
Tom Chichester
Mark Mc
Are you a Digix Tablet and eReader Expert? Answer questions, earn points and help others
