Question about Whirlpool 8182697
F6 CODE ON WHIRLPOOL WASHER - Whirlpool 8182697
    New Friend:
    Problem Solver:
  • 14 Answers
F06 -----Drive motor tachometer error
the control is unable to properly detect motor speed and the machine will shut down.if a failure occurs during high speed spin the door will be unlocked after the drum has stopped rotating.
POTENTIAL CAUSE
check the harness connections between the motor and ccu
check the tacho circuit on the motor
check the motor resistance winding
Posted on Mar 07, 2015
What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
Error code F06 means Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
2/ Check the Drive Motor
3/ Check the MCU
4/ Check the Wire Harness
Replace failed component or contact an authorized repair agent.
Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What does F6 code mean?
F6 code means the control board can not detect the speed of the motor. The failure could be the motor or the MCU does not work.
Oct 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I had whirlpool duet wfw94hex0 error code f6 -e2
If it's the same as a UK version, F6 is a motor speed sense fault
Dec 23, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Model number wfw9250ww error code e1 and f6
How to fix a error code of E2F3 on a whirlpool duet model # wfw9250ww00
May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a F6 code problem with my Whirlpool Duet FL Washer, any ideas?
F6 is an issue with the motor drive tachometer. Most often this is caused by poor connections at the machine control or motor controller. Locate the main machine control by removing the top panel and the motor control by removing the rear panel. Remove each connector, ONE AT A TIME, and reinstall. If this does not work, you likely have a faulty control.
Kelly
May 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is an F6 on my duet washer? I already
three things.... could be the motor, could also be the MCU (  motor control unit ), could be the wiring harness .  check the wiring harness between the speed sensor at the motor and the MCU.  i have run into all of those being bad on different machines.
Aug 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
See all Whirlpool 8182697 Questions
Whirlpool 8182697 Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
