Question about Electric Currie EZIP 500 Scooter
Where is fuse located on 450 ezip electric scooter
2 Suggested Answers
aparsons89
  • 40 Answers
SOURCE: ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Posted on May 13, 2009
I have a ezip 450 electric scooter doesn't run.I
Check the brake micro switch and brake coil resistance plus all wires in this area.
Oct 09, 2014 | Health & Beauty
How do I fix my ezip 450 electric scooter
Your battery may have gone bad. It may have enough juice to turn on the lights but not enough to run the motor. Try connecting the battery directly to the motor terminals. If it runs ok them you may have a bad speed controller.
Sep 20, 2014 | Health & Beauty
What makes a 24volt 450 watt DC motor overheat and smoke
hi, worn brushes , no unless they arcing on the motor, chipped brushes once again if they touching at a point yes they could arcing and result of that smoke, however i believe your motor could be breaking down, resistance wise , hence the fact it getting too hot because a resistance is building up in the windings,, another situation could be the controller could be burning out the motor....
check the resistance of the motor by disconnecting it and use a smart meter or electrical meter to a take the lowest ohm reading , what is it ??
Regards
Rob
www.gewizrepairs.co.uk
Apr 21, 2014 | Currie Technologies Electric Scooter: EZIP...
Where is fuse located on ezip 1000
There is a fuse in front of the battery area that is covered by a metal cover plate. There are two screws on the top of the L-shaped cover which might be hard to unscrew. Exercise patience, use penetrating fluid(s), & try not to de-form the screw head. Otherwise, you shall probably have to cut them off to get the plate off & work the screws out with pliers.
Dec 28, 2013 | Ezip Currie 1000 Electric Scooter, Black
Brake stuck on
remove first the tire then if will unlock the bake...but clean the brake pad check if still have a thickness in the brake pad.....u
Dec 09, 2013 | Ezip The E-450 Scooter
All three lights on throttle are flashing, motor will not run.
Have you had it in freewheel mode? It sounds like its not quite clicked back in to drive mode.
Oct 18, 2013 | Currie Technologies Electric Scooter: EZIP...
Ezip 150 electric scooter. won't start.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Electric scooter problem
Yes, you will need to get a charger based on the number of 12 volt batteries in the Scooter. I recommend TNC SCOOTERS to buy the chargers. Very good service and lower than most prices.
Dec 17, 2008 | Electric Currie EZIP 500 Scooter
Electric Currie EZIP 500 Scooter Logo
382 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
