Question about Singer Sewing Machines
How to wind bobbin for singer 9113 - Singer Sewing Machines
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
dupina
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
  • 3 Answers
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
SOURCE: Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Posted on Mar 08, 2009
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Trying to wind the bobbin on my singer 6268 but the thread keeps winding under the bobbin. What am I doing wrong?
if the bobbin winder is driven of the end of the machine then you may have to guide the thread as it winds onto the bobbin
if you are allowing the thread to come directly from the reel and it is not in line to the bobbin then what you have is what will happen
Jul 21, 2015 | Singer Sewing Machines
Manual for a singer 9113
how do you thread the bobbin on singer 9113 machine
Mar 15, 2009 | Singer Sewing Machines
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Singer 2662 winds bobbin only half full.
there is an adjustment on the bobbin winder. Just bend the little spring flap that rides inside the bobbin while winding. Bend it up a little. The flap being pushed up is what releases the shut off
Jan 05, 2009 | Singer 2662
Sewing Machines Logo
176 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
