Question about HP DeskJet 890c InkJet Printer
Printer takes a long time to start
I have had this problem for some time now. I can no longer use the on/off button on the front. Instead I have to switch it on at the plug. On average the printer takes about 30 mins to switch on. Doesn't make any difference if it's plugged to my PC or not. A friend of mine has had an identical problem on a a different HP Printer. Anything I can do to get this sorted? Thanks, S.
    Problem Solver:
  • 8 Answers
Hi! Sorry to hear of this issue! There are a few steps you can do to diagnose the issue. If these steps do not work, let me know and I can suggest other steps or which part you may need to order. I can be emailed directly at: bosscomputers@comcast.net or http://bosscomputers.org Follow the steps below to ensure power is properly supplied to the printer: Check the power module part number against the part number listed in the User?s Guide to ensure the proper power adapter is being used. Disconnect the power cord from the wall outlet. Disconnect the printer data cable from the printer. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning. If the power cord does not work on the other printer, it is defective. Replace the power cord. If the power cord works on the other printer, then this printer is defective. Service your printer. If another printer is not available to test with, carefully inspect the power cord for damage. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer. Again, if these steps do not work for you and the issue is still present, then the printer will need a specific part - and I can tell you how to order, install, etc, so that you can do the repairs yourself! =) Just email me at bosscomputers@comcast.net Please rate my help for you too, so that I can track your progress as well as helps me get a better rating =) I really appreciate that, as well as hopefully being able to get your issue resolved/fixed!! ~Darrin~
Posted on Jun 12, 2007
All led are blinking
powering up the printer whilst holding the tick/menu button takes you to service menus/diagnostics and is perfectly normal. Suggest you dont HOLD buttons down for excessive time and instead just press and let go. this should work better for you!
Feb 19, 2014 | HP LaserJet 1150 Printer
Tip
How-To Save hundreds of dollars by using all the toner in your HP-2550 series...
Most laser printers on the market today use a computer chip to tell the printer/computer when it's empty. The chip does not have any kind of physical sensor to tell whether the toner is actually low or not, instead it keeps track of how many pages were printed using the toner cartridge. (there is a separate chip on each cartridge, so in a color printer there are 4 chips one of each color and one on the black)
The chips tell your printer/computer that they are low or empty long before the toner is actually low or empty. If you replace them when the computer tells you to you are throwing away a lot of good toner.
To make things worse, the printers will not print at all (color or b/w) once it believes that one of the cartridges is empty.
There are 2 ways to 'trick' your printer into not believing that a cartridge is empty.
(Solution 1)
The chips that are on the cartridges can be swapped out with new ones. There are several vendors that sell aftermarket chips for your 2550 toner cartridges. Do a general search for 2550 reset chip and you will find vendors that sell reset chips. You can also find them on eBay for around $20-$25 a set.
The chips themselves are very simple to replace. Use a small screwdriver and pry off the old chip. They are just held in place with a strong piece of double sided tape. If the old tape is still there and good, you can just put the new chip in it's place, otherwise stick the new one on with some double sided tape.
This trick can also be used to extend the life of your printer drum, as you can buy reset chips for it as well.
(Solution 2) A bit clunky, but this one is free
You can literally trick your printer into not reading the info from the chip and thus not stopping you from printing. This solution is not as nice and clean as the first one, but it does work and it's free. You will have to repeat this solution from time to time if the printer stops working.
  • Step 1: Power off your HP2550 printer.
  • Step 2: While the printer is off, press and hold the big green button on the printer.
  • Step 3: While still pressing the green button, power the printer back on using the power button (lower back corner on the left side of the printer).
  • Step 4: Continue to hold the green button while the printer initializes. During this time all of the front lights will turn on one at a time and then all but the first green light (the ready light) will turn off one at a time - this step can take several minutes to be patient and keep holding the green button.
  • Step 5: When all the lights have turned off except the front green light, release the big green button. The front lights with flash a few time, while they are flashing, press and release the red circle button 1 time.
  • Step 6: You may have to reload the printer driver at this point. If your computer has detected new hardware then go ahead and reinstall the driver.
Be aware
  • Some of the back cartridge lights (the back 4) may stay on or flash, this is OK.
  • The front green 'Ready' light will no longer be on, again this is OK.
  • If at any time your printer stops printing all together, then go through these steps again. I have had to redo this about 10 times over the past 2 1/2 years. It is a nuisance, but it saves a great deal of money.
  • If this does not work the first time then try it again. Each step must be done in order and correctly otherwise it does not work.
I have had my printer for almost 3 years now. The original cartridges that came with my printer stopped working because they told the printer they were empty about 2 1/2 years ago. I started doing this at that time and all 4 of mine (I have a 2550 color printer) are all still working and have not started to fade, so there was a lot of toner left when my printer said it was empty.
on Jan 06, 2010 | Office Equipment & Supplies
Tip
How to use all of the Toner in your HP 2550 series printer
(Solution 1)
Be aware
on Dec 30, 2009 | HP LaserJet 2550n Printer
Hi, I have a HP deskjet 3325. As soon as i turn on the printer, the carriage starts moving left to right violently shaking the whole table. Pls help
Hello.
Try this: Open front cover. Put out a ink cartridges, then reinstall them.Hold power button and then fast open and close the front cover (in this time you should holding the button) of the printer 5 times. This must take a printer test page, but in some models of this printers class, this method makes also a print head alignment.
I hope this will help.
Jul 06, 2012 | HP DeskJet 3325 InkJet Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Xbox 360 takes a long time to connect
Hello, I am sorry about your issue. Are your cables longer that 15 feet. If so that could be the issue. Press and hold the game button for several seconds. It should change back to game. Thank you, Onkyo USA
Jun 30, 2017 | Onkyo TX-SR606 Receiver
The printer prints very slowly all of a sudden. It took over an hour to print out 4 pages. I've unplugged everything. I've cleared the print ques. Same thing is happening when I copy. Help!
If the output quality has improved greatly, you may have selected the "High" quality instead of "Normal". The front panel should give you a clue as to how to adjust.
Jun 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
Waste Ink Tank is full and printer will no longer work. How do I repair this problem?
I wouldn't override that error message. Best bet is to open up the printer and give it a good cleaning. If you're unfamiliar or not comfortable with the procedure, take it to your closest computer repair store to have it serviced.
May 12, 2009 | Canon i9100D (Bundle) Photo Printer
SRA3 printout is not same size but slightly smaller
Try this!
Phaser 7300 Printer: Turn metric defaults on using the printer's front panel
The Printer's Configuration Page will show that Tray (1-5) is loaded with Tabloid Extra instead of SRA3. To have the image scaled to SRA3 instead of Tabloid Extra, turn On Metric Defaults at the Printer's Front Panel.
You can switch Metric Defaults On or Off at the Printer's Front Panel as follows:
  1. With Menus highlighted, press the OK button.
  2. Select the Printer Setup Menu by pressing the Down or Up Arrow button.
  3. Press the OK button.
  4. Select the Reset Printer Setup Menu by pressing the Down or Up Arrow button.
  5. Press the OK button.
  6. Select Metric Defaults by pressing the Down or Up Arrow button.
  7. Select On or Off by pressing the OK button.
Dec 29, 2008 | Xerox Phaser 7300DN Laser Printer
Printer responding but nothing printing!!!!
An error has occurred when printing the following print job. Click cancel to stop printing
Jul 28, 2006 | Epson Stylus Photo R2400 InkJet Printer
HP DeskJet 890c InkJet Printer Logo
140 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
