Question about NorStar M7310 Corded Phone
Old Norstar phone-one line seemingly tied to one extension
Call came in on main line, I placed on hold. I then, intercomed the extension I wanted. He never picked up, he just answered that he didn't want the call. When I went back to the caller, I couldn't get to the call. Now everything is tied to his intercom. Everytime I pick up that line his intercom immediately rings. And I have to go all the way to his office, hit intercome and release for it to stop ringing. Can someone help?
    Scholar:
  • NorStar Expert
  • 277 Answers
You most likely need to call in your tech who looks after the programming there.
Needle in haystack, sticky button, bad programming, glitch in system, answer dn etc.
Posted on Dec 11, 2012
5 Suggested Answers
  • 22 Answers
SOURCE: Intercom
This is a programming issue with the phone .There should be a pull card located in the base of the phone that will give you instructions on how to program the phone.
Posted on Jul 09, 2008
SOURCE: Incoming calls ring on intercom rather than appropriate line.
Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
Posted on Jan 02, 2009
consultel1
  • 860 Answers
SOURCE: Ringing multiple intercom numbers at once
That was a good solution to the problem. way to go.
Posted on Mar 01, 2010
consultel1
  • 860 Answers
SOURCE: lines ring to intercom
It sounds like although they're labeled as line buttons actually they're programmed as station buttons.
If you press feature *0 and one of the buttons it will tell you what the button is programmed as.
Also did you try pressing the intercom button then dialing 9? that might be the way the set was programmed.
Posted on Mar 05, 2010
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
New phone - plug in, know what the extension is, how do I know what the direct line is?
If you want to know the extensions number of your phone of any information about the programed feature on any button you just click on feature (button with nortel logo) then * then 0 then the button and it will give the information about the button. For extension you should use the intercom button which is normally last button on the buttom of your rigth hand side.
Jan 07, 2013 | Nortel Norstar 16-Line PBX Speakerphone
Privacy
Unfortunately you cannot toggle this feature.
On extension 10 or 11
Feature 00
Left Intercom, Left Intercom, Right Intercom
Enter extension number that you don't want to ring
hit the line key until display shows No ring
To do next extension : Right Intercom and enter next extension number.
Follow same procedure for all extensions.
Feature 00 to exit programming
Let us know if you need additional assistance.
Cheers
Jul 16, 2009 | Avaya Eurostyle 18D Corded Phone
Call conferencing
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
May 11, 2009 | NorStar Meridian M7310 Phone
Intercom
Try FEATURE 6 6 and the extension of the phone that you want to page to.
Mar 04, 2009 | NorStar Meridian M7310 Phone
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again! ldtnsj.com
Jan 20, 2009 | NorStar M7310 Corded Phone
Line in Use
Try pressing Intercom then 9. Should redirect you to the next open line.
great when all lines look like they are tied up!
Dec 18, 2008 | NorStar M7324 Telephone
Dec 08, 2008 | NorStar M7310 Corded Phone
Norstar M7310 Phone's Buttons Don't Work At All
What system is this on? Sounds like the system is going downhill.
Nov 18, 2008 | NorStar T7316E Corded Phone
How do I turn off the ringer on my extension so that everytime a call comes to the main switch I can't hear it -- I only want to hear the intercom rings
No where have I seen this answer documented in the user guide. LUCKILY someone from our company in past did document the procedure. Feature **266344, PW: 266344 (this is different from the listed PW of 26346). Press the top arrow on the right. Enter the extension you want to turn off. Press the top right arrow again twice until you see Line assignment and press the top right arrow again. Enter the line you want to change (001) Then hit "change" until you see the status you want to achieve (appear only). Scan through all the remaining lines in your trunk. Don't worry- only took me an entire day to find this configuration!
Nov 05, 2007 | NorStar M7310 Corded Phone
NorStar M7310 Corded Phone Logo
65 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
