Question about Refrigerators
My refrigerator door is not staying shut, it seems like the magnetic seal is gone ?
This is a 7 year old side by side Only having trouble with the Refrigerator side, Freezer still seals fine !
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
HVACRH20
  • 237 Answers
SOURCE: freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Posted on Nov 10, 2006
Adjust the front rollers so frig lean toward back and live with the results. From a GE tech
Posted on Aug 27, 2008
tborn6
  • 700 Answers
SOURCE: Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Posted on Mar 29, 2009
  • 19 Answers
SOURCE: Amana ATB1832ARQ Top Freezer Refrigerator - Freezer door not seal
OPEN THE DOOR WIDE . YOU SHOULD SEE THE HINGES THAT SUPPORT THE DOOR. LOOSEN THE SCREWS THAT SUPPORT THE DOOR----JUST LOOSEN , THEN LIFT UP ON THE DOOR AND TIGHTEN THE SCREWS. NOW YOU CAN LET GO OF THE DOOR. I HOPE THAT WORKS FOR YOU . GOOD LUCK.
Posted on Apr 22, 2009
  • 126 Answers
SOURCE: Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Posted on Jun 26, 2009
I have a Whirlpool GX5FHDXVY, only 3 months old, the freezer drawer does not seem to be sealing, it will be several days before I can get a repairman out, is there some easy way to fix this? I don't see...
May sure the drawer is installed correctly. Then with a hair dryer gentle heat the seal and adjust it to touch the cabinet. use a pen or pencil to gentle adjust it to touch the cabinet. One it is touching and will stay allow the door to stay in that position until the heated area of the gasket is cooled and can retain its shape.
Dec 31, 2017 | Whirlpool GX5FHDXVY Stainless Steel (248...
The refrigerator door side does not shut tightly. The gasket seems to be ok and we leveled the unit. Still not shutting tightly like the freezer side which seems to have a magnetic pull to assist close....
Check bottom hinge cam riser located on bottom hinge the pin that goes inside the door it's plastic it's a 2 piece part 1 part goes over hinge pin and the other goes inside door hole. They get worn and break. If you replace this make sure you get both parts until you do try adj. top door hing to get the door tighter.
May 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Side by side door not shutting properly
There are magnets inside the seal this is what keeps it closed. Either the seal is damaged or the magnets are worn out. They do wear out but usually not for at least 10 years depending on the usage.You can go to www.appliancehelponline.com for a diagraam or illustration of your specific model. The parts also come with installation instructions.
Mar 31, 2010 | Kenmore 57029 Side by Side Refrigerator
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Aug 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Door on refrigerator won't close and stay closed. Seems as if there is no magnetic seal and this just happened all of a sudden. The seal around door is not cracked or old. Freezer side is OK.
You will need to replace the gasket. The gasket seems to have failed and that is where the magnet is. You can try to clean the magnet surface and the door surface with rubbing alcohol but you are most likely going to need to replace the gasket
Apr 28, 2009 | GE GSH25JFR Side by Side Refrigerator
Refrigerator
use a hair dryer to heat the gasket up and gently pull all the bends and wrinkles outs. this takes a tremindous amount of patients even with us techs, so work slowly. once you have that done and the gasket shift to form the door seal put a light coat of vasaline all the way aroung the gasket then push the door shut making sure you gasket is touching the door seal all the way around it mat take going over it again with the hair dryer with the door closed to get it to form correctly, once formed don't open the door for a min. of 4 to 8hrs if it can be avoided and after that make sure you close the door and it seals for the next week to 2 weeks which is about the time it take for it to cure properly
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 13, 2008 | Refrigerators
Fridge Door not shutting/sticking
the fridge door stays shut only by strip magnets inside the door seal. cause is possibly that the hinges are out of line or the cabinet distorted. try levelling the fridge and tilt slightly backwards
Apr 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Freezer door won't stay shut
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
